i have read on here about cutting around the speedometer for disassembly. well i had a thought tonight.
what about instead of cutting all the way around - just cutting a decent sized hole in the plastic? seems to me if you could set your dremel bit to a very shallow depth, it would be easy to cut a hole large enough to clean the gears without damaging the insides. then just wrap duct tape around the plastic housing a couple times to cover the hole back up. would also be easy to get apart again if needed. would look perfectly stock once put back together too.
those that have disassembled a speedometer already - do you think that this would work? and if so - could you advise me on the best location for this hole?
THANKS!
THANKS!
