compression question
  • xswilly
    • Jul 2003
    • 462
    • Hollis, maine
    I bought a very negelcted 80G
    for parts, the motor has compression of
    100-110-90-100
    has 44 thousand miles on it
    i slapped a set of carbs on it that i had for spares
    it started right up and idled fine
    can't take it down the road, as the condition of the bike isn't very good,
    any opinions on the life left in the motor
    http://home.securespeed.us/~xswilly/
    78E main ride, since birth the "good"
    78E Parts, the "bad" fixing up now
    78E Parts the "ugly" maybe next year
    79F Parts
    80G Parts
    75 DT 400B enduro
  • randy
    • Dec 2003
    • 4521
    Willy, did you check the compression with the engine warm?
    Randy
      If you are interested in using this engine, get it running and let it come back to life for a few hundred miles. Like the previous suggestion, get it to operating temperature to do a compression test. Also, hole the throttle open while doing the test. That low value has a chance of coming up.
      • xswilly
        • Jul 2003
        • 462
        • Hollis, maine
        did the test warm, full throttle
        then sprayed some oil inside and the compression went up 10-15 lbs
        the engine would be more of a spare for me
        no plans to use it in the near future
        79F Parts
        80G Parts
        75 DT 400B enduro
        • randy
          • Dec 2003
          • 4521
          If the compression only went up 10-15 lbs with a shot of oil, sounds like rings AND valves have seen better days. Good candidate for a re-build.
          Randy
          • steelcat
            • Feb 2004
            • 68
            • Elko, NV
            When I shimmed the valves on my F, my compression jumped from the range you have to 137psi. It sounds like it would be worth doing some tinkering on this winter.
            Ken
            '79 xs1100f
            '79 xs1100sf
