can leaking exhaust cause poor performance
  • tab1324
    • 303
    • Brooklyn Park, MN
    When I recently changed my tires, I jacked the front of the bike up with a hydraulic jack under the oil pan (with a block of wood). I think I may have disturbed my exhaust because I've noticed a difference in performance and noise since the tire change. Tonight after a 27 mile ride home from work, I checked it out and the #3 pipe flange is completely loose. Also, the right side header / muffler connection appears to be leaking. The pipes are original but are generally in very good shape.
    Questions:
    1) Can the leaking exh. cause poor performance?
    2) Is this just a matter of simply tightening things up again or are there more extensive repairs required?
    Thanks!
    Tom B.
    Re: can leaking exhaust cause poor performance
    1.- Yes, leaking exhaust will cause poor performance. You can even cause engine damage.
    2.- You might be able to tighten the flange nuts if there is any give left in the crush gaskets. They are only a couple of dollars each. They are likely needing to be replaced.
    Originally posted by tab1324
    Questions:
