I tried to modify my last post but could not so I will finish with a new one. The needles are in the stock location and the plugs look good. I use one step colder plug on the center two cylinders. I have had this thing since it was new and have tried every carb modification known to man. Those dyno jet kits are a waste of money and I have a spare set of carburetors to prove it. I tried a set of FJ 1200 carbs a few years back which required a lot of fiddling to get them to fit properly, but I concluded they were to big for my combination. You, Jeremy, said your motor had 170-180 psi @wot. The book says 145psi @sea level and I have 150 with a 3% leak down rate which means you have a bunch. The best reference I have ever read about the internal combustion engine, is a book called, The Internal Combustion Engine In Theory And Practice by Charles Fayette Taylor. It has been my bible no matter if I was building a 540 c.i. rat motor for my race car or working on my old Yamadog.
Dyno Test
Tags: None
Dyno Test
Thanks Ratbyk for leading me to Jeremy's dyno work.81 Black "1179" Xcessively trick Super Special. One owner (me). -
Hello there Dan,
Nice to see this thread still lives on after a year or so. If you saw the charts, you'll see that I had a bit of a rich mix fed by the idle jets. After that post died off, I ended up going from 42.5 to 40.0 on the idle jets and that eliminated the richness and hesitation off idle. In addition to better power and rideability, I have been able to squeeze over 40mpg out of this thing on numerous occasions, amazing!! Welcome to the forum and if you get a chance to get your bike on a dyno, show us the results so that we can build on this whole jet tuning theory.
Take care,Jeremy
1979 XS11 Special
2002 Ducati ST4S
2012 BMW F800R
1981 Suzuki GS450E
1982 Honda XL500RComment
