front brake dragging
  • tab1324
    • 303
    • Brooklyn Park, MN
    I changed my tires last week and when I put the front wheel back on, the front brake was dragging. I've never had this before - I rebuilt the front master cylinder and calipers and have installed a new stainless line. It seems to me that the piston isn't returning - is this the dreaded "spooge hole" scenario?? How can I diagnose?
    The other thing I noticed when I put wheel back on was there is a slight gap (1/16") between the wheel hub and the fork connection. Is this normal or should it be tight up to each fork connection?
    Tom B.
  • pathfinder
    XStremely XSive(Deceased)
    • Apr 2004
    • 483
    • Houston, TX
    Had the very same problem, see my post http://www.xs11.com/forum/showthread...&threadid=4013
    78XS11E
    • Pat Kelly
      • 3046
      • Golden Valley, AZ
      Make sure to re-install in the correct sequence as per the manual.
      Pat Kelly
      <p-lkelly@sbcglobal.net>
      1978 XS1100E (The Force)
      1980 XS1100LG (The Dark Side)
      1999 Suburban (The Ship)
      1994 Dodge Spirit (Son #1)
      1968 F100 (Valentine)
