Hello to all.
I had posted a while back about voltage at headlights. had read interesting article about using relays to get brighter headlights. did some testing today with my bike.got some interesting readings.first i made sure my battery was fully charged. started bike up and checked voltage at headlight. had 11.5 to 11.8 volts.
voltage did not go up with engine reved. so proceeded to take seat and tank off for better access. checked voltage at battery got 14.2 volts w/engine reved up. checked voltage going to rlu still 14 volts. checked voltage coming out of rlu about13.8. checked voltage at fairing wiring connector still 13.8.unplugged headlight got 13.8 volts.plugged light back in back down to 11 volts. new bulb. double checked all readings.all the same. now i wired in a relay. all readings the same except now i have 13.8 volts at headlight. light looks brighter. i don't see how a dvom could be lying to me. even double checked my readings again.still the same 13.8 volts at headlight with relay installed. all readings were at 3000rpms. before installing relay and after. any insight or feed back.don't think i left anything out .
