Have just cleaned the carbs on my 81 special. Starts,Runs and idles smooth as silk. Took it for a test ride and it was smooth but sluggish until 5k then it will not go any more. Just like a gov. kicked in.
Pulled the sidecover and the vaccum advance will only let it go so far when you rev the beast up. If you manually overide then it will red line with no problem. What do you guys think? I have read several other threads on similar problems but none quite like this. It has after market 2 into 1 exhaust with no crossover. Are my jets to big or to small. It has a K and N stage three jet kit installed. Don't know how it ran before, this is a back from the grave restoration project.
Thanks for any help or suggestions,
Dan
Dan
