Electrical or Ignition Issue
  • knclark
    • Aug 2004
    • 3
    • Las Vegas Nv
    Hello to all,
    I am new to this forum. I have a 1980 XS 1100 Midnight Special. It has always been a sound bike intil just recently. I had stored it for two years. A month ago I took it to a shop to get it running. Tune up Brakes New Battery etc. It started and ran great after coming out of the shop.
    I then moved to Las Vegas I did not ride it for about three weeks until I put new plate on it. The morning I went to get the plate it started right up. I rode about 2 miles to DMV and it sat for about 90 minutes.
    Getting tags in Las Vegas is a nightmare any where from 90 minutes to 4 hours.
    Any way after getting the plate it started right up. I then rode for about five miles then parked it for about 3 hours. When I went to start it I turned the key to ON, yet not start nothing the green nuetral light did not come on nothing.
    Does anyone have any suggestions as to why this is happening.
    Thanks
    Kelsey
    knclark
    Main fuse
    Hi Kelsey,
    No power, nothin'?
    A total power failure like you describe is an open circuit somewhere.
    First check the obvious, did the killswitch get turned off? Sometimes helpful passers-by do this.
    If not, check the main 30 Amp fuse. It's hidden behind the leftside cover. It it ain't blown it has been known for that fuse holder to lose it's grip on the fuse and open the circuit.
    Fred Hill, S'toon.
    • mitch
      • Oct 2002
      • 934
      Main fuse
      you might want to check your main fuse it is under the seat if im not mistaken in a red holder. Or under the left side cover im not sure where it is on the midnight. HTH...........MITCH
      Doug Mitchell
      82 XJ1100 sold
      2007 Stratoliner 1900 sold
      • dbyers
        • 70
        • Douglasville, Ga
        What about the battery? Could the new battery have been charged and since there is a problem with the charging system the battery is now dead. Just a thought...Happened to me.
        "There are old bikers, and there are bold bikers, but there are no old bold bikers."
        • knclark
          • Aug 2004
          • 3
          • Las Vegas Nv
          Thanks for the advice. Battery has a charge and main fuse is good and securely in place. Any other ideas?
          Kelsey
          knclark
          • cruiser
            • Jul 2004
            • 393
            • Winona, Minnesota
            If you are sure you have battery voltage and fuse is good then check ground/negative cable from battery. First check connection at battery then follow cable to where it fastens to frame. The connection at frame should be loosened apart and cleaned.
            Might also want to check positive connections while your at it.
            XJ1100 Ruby Red
            XS1100LH "Midnight"
            1972 MGB Roadster "sold"
            • Geezer
              • May 2003
              • 2985
              • Willamina, Oregon 97229
              Kelsey
              Replace the main fuse anyway. Sometimes a fuse will look good but be broken inside on one end.
              Geezer
              • MartyA
                • 2148
                • NW PA
                Mine did that a couple of years ago. Rode for a few years after I bought it and one day when I got out of work I had nothing, no neutral light, no horn, nothing, completely dead. Turned out the fuses had tiny bit of corrosion on the points of contact with the fuse holders. I checked the main fuse, it looked good, but I took it out and wiped it clean, wiped the fuse terminals off and they broke. All the fuse terminals were corroded so bad that as I pulled the other fuses to check the terminals fell off the fuse box. I jumped them all just to get home and replaced all the fuses and terminals.
                See the MODs page for a couple of nifty replacement fuse panels.
                Marty in NW PA
                This IS my happy face.
                • Czekus21
                  • 1069
                  • Keosauqua (Southeast) Iowa
                  My 79sf did that about a year or so ago. I just jiggled the key a few time, Cussed her out, threatened to kick her out and she fired right up
                  S.R.Czekus
                  1-big XS patch
                  1-small XS/XJ patch
                  1-XS/XJ owners pin.
                  Just do it !!!!!
                  • pathfinder
                    XStremely XSive(Deceased)
                    • Apr 2004
                    • 483
                    • Houston, TX
                    My sugestion
                    MartyA I didn't see you were you there.
                    Do the mod on the main fuse block they are notorious for leaving you stranded.
                    78XS11E
                      • 8061
                      I see Parts 'N More has a reproduction fuse box for the XS1100. My XS650 started losing its grip on the fuses after 20 years. I just put a reproduction unit in it a few weeks ago. It was easy. The problem it see with it is that is just like the original, so in another 20 years or so, I'll have to do it again!
                        Sometimes gel-type batteries fail suddenly when they get old. I had it happen to me.
