I just took my XJ out for a little ride around the neighborhood while trying to sort out my carb and/or ignition problems (see my previous thread about pilot screw/jets). Anyway, I can see how you guys get so addicted to these bikes! WOW! I had only rode it once last fall right after I got it running again, and I only went about a 1/4 mile and back home. Mostly just checking tranny, clutch, brakes, etc. This time I decided to really flog her a bit.
Damn! Even with it not running right at lower revs, this thing accelerates faster than anything I've ever operated. Not too good below 5k, but after that, it's like being strapped to an ICBM! Every time I wound it out, grabbed the next gear and hit the throttle again, I could feel the forks top out and the front wheel trying to come off the ground. I think it actually did a couple of times! This thing has some serious cajones! (Probably more than I do!) I can't imagine what it will be like once I finally get it running properly. Now if I can just figure out what the problem is............
