Basic Carburetor Operation.....
  • CMA1
    • Jul 2003
    • 114
    • Ontario, Canada
    Found this on the Web... thought you'd get a kick out of it....
    Basics of Carburetor Operation
    The basic secret of carb function is that inside each carb are
    thousands of tiny gnomes; each with a small bucket. As you open the
    throttle, more of these gnomes are allowed out of their house and
    into the float bowl, where they fill the buckets and climb up the
    carb’s passages to the intake, where they empty their buckets into
    the air stream.
    But, if you don’t ride the bike for a while, bad things can happen.
    Tiny bats take up residence in the chambers of the carb, and before
    long the passages are plugged up with guano (that is.... bat-****).
    This creates a gnome traffic jam, and so not enough bucketfuls of fuel
    can get to the engine. If it gets bad enough, the gnomes simply
    give up and go take a nap. The engine won’t run at all at this point.
    Sometimes you’ll have a single dedicated gnome still on the job,
    which is why the bike will occasionally fire as the gnome tosses his
    lone bucket load down the intake.
    There has been some research into using tiny dwarfs in modern
    carbs. The advantage is that unlike gnomes, dwarfs are miners and
    can often re-open a clogged passage. Unfortunately, dwarfs have a
    natural fear of earthquakes, as any miner should. In recent tests,
    the engine vibrations caused the dwarfs to evacuate the Harley-
    Davidson test vehicle and make a beeline for the nearest BMW
    dealership. Sadly, BMW’s are fuel-injected and so the poor dwarfs
    met an unfortunate end in the rollers of a Bosch fuel pump.
    Other carb problems can also occur. If the level of fuel in the
    float bowl rises too high, it will wipe out the Section 8 gnome
    housing unit in the lower parts of the carb. The more affluent gnomes
    build their homes in the diaphragm chamber, and so are unaffected.
    This is why the bike is said to be "running rich".
    If the fuel bowl level drops, then the gnomes have to walk farther
    to get a bucketful of fuel. This means less fuel gets to the engine.
    Because the gnomes get quite a workout from this additional
    distance, this condition is known as "running lean".
    The use of the device known only as the ’choke’ has finally been
    banned by PETG (People for the Ethical Treatment of Gnomes) and
    replaced by a new carb circuit that simply allows more gnomes to
    carry fuel at once when the engine needs to start or warm up. In the
    interests of decorum and respect for the departed gnomes,
    I prefer not to explain how the ’choke’ operated.
    You would rather not know anyway.
    So, that’s how a carburetor works. You may wish to join us here next
    week for electricity 101, or "How your bike creates cold fusion
    inside the stator, and why the government doesn’t want you to know
    about it."
    Pete Snidal, Grand Forks, BC Canada
    - Ride Safe, Larry
    '79 Special
  • nashville_bill
    • 605
    • Nashville, TN
    I can't wait for "Electricity 101".
    Bill Murrin
    Nashville, TN
    2005 DL1000 V-Strom "WOW"
    2005 FJR1300 Newest ride
