tail light out but brake lights work
  • tab1324
    • 303
    • Brooklyn Park, MN
    My tail light (running light) isn't working - presumabely since the crash a month ago but I just noticed it. Brake lights work fine and I look at the bulb filaments and they're ok.... I checked voltage at the sockets and have nothing.
    When I crashed, the left front signal light got bent back and had severed the wires leading to it. Is there anything else in the headlight bowl that could've gotten disconnected? There isn't a seperate fuse for the rear running light circuit is there?
    Thoughts / suggestions?
    Tom B.
  • pathfinder
    XStremely XSive(Deceased)
    • Apr 2004
    • 483
    • Houston, TX
    You probaly just shook a ground loose. I'd check the the connection under the seat and also inside the light itself. Remove the lisense plate and check in there also. Glad to see your keeping the bike.
    There's always a way, figure it out.
    78XS11E
