hi some nobb edd has cut my ears in two i have nearly 7 inch of tube with a piece cut so its 5 inch and 2 inch and the ears are 3 inches to the centre of the head light bolt hole are the ears different for all models must find my parts disk and also someone said my calipers bolted on wrong compared to his so want to know what the fitting should be for an sf model (where the caliper boltas to fork leg)thanx see you
head light ears and forks are mine right for my sf
Hey there Gaffer,
My SH also has the 7" long tubes, but the distance to headlight holes is ~4" from edge of tube to center of holes, they are curved a bit, and your's might have gotten bent more, pulling the headlight closer to the forks? The standards ARE different, but I'm pretty sure the Specials are all the same!
T.C.T. C. Gresham
