speedometer
  • raider
    • 38
    • warr acres,ok
    speedometer
    ok..once again I come for help...
    I just got a new speedo cable....replaced the speedo and eveything recently.....the problem here is even after hiting 3rd gear it moved very slowly up too about 20mph....upon slowing down it didn't move just stayed there....
    so basically,,,what the hell!!! everything hooked up fine...even took twive too get the right cable(first time was for an H model,mine is SH) so I'm at a loss here....
    please tell me if I'm missing something or if i just got taken for crappy parts
    81 xs1100sh......."the black-*itch"
    NOT ALL MEN ARE ANNOYING.......
    SOME ARE DEAD
    Okay, leave the end of the cable off of the speedo, and support the front tire up off the floor so you can spin it, and watch to see if the inner cable is turning. Also, you can take the old cable, put the gauge part into the gauge, put the other end in a drill, and spin it with the drill, and see what the gauge does, both old and new! If the gauge reads much farther than 20mph, then it's probably the gear assembly inside the front wheel!?
    • Nastydude
      • Jul 2004
      • 29
      • Saskatchewan
      dude had the same problem my self. took 3 miles for the speedo to show speed i was travelling ( kind of) and you would be turning corners at 100 km off the highway cause the speedo was too slow. took the speedo apart last night ( not an easy job and I was too rammy and broke the glass but i fixed the problem) there was some type of thick clear grease in the speedo which was restricting the movement of the wheel. there is a wheel which kind of looks like a dome with a small rod attached that your needle sits on. On the top side of this dome wheel there is a little shield and the grease was between the shield and the wheel I spayed it heavily with WD-40 rotated and wiped the wheel repeatedly untill all worked freely and now it works good just got to replace my glass now which is a pain but I can do it my self so it's not a big deal. hope this helps.
      • raider
        • 38
        • warr acres,ok
        sounds about right.....i know my speedo is off a bike that sat in the elemants so that is probably whats up. it keeps trak of the miles good just the needle is slow too react which is just like what u said....i can try that solution easy enough anyway,lol
        SOME ARE DEAD
