Hi all. I have an interesting problem which I'm not sure is resolvable, but I'm looking for any input you might have.
First off, I have a 1980 xs1100sg.
So, I ordered two crankshaft oil seals (the ones at the end of the crank that fit into the gooves in the crankcase halves).
These are OEM part numbers 93101-32087-00 and 93101-32088-00.
the 32087 part came as just that. the 32088 seal has been superceded twice, and the end result for "correct" part number comes to 93101-32144
That's all fine, except that it is an obviously different part. Actually, they are the same except for the glaring difference that there is no ridge along the outer circumference of the seal that would seat itself in the crankcase halves. Yamaha sent me another one in case the part had been mispackaged, but same problem. Basically, I think this is a case where Yamaha made an error in compatible parts to supercede to, and now there isn't anything I can do to get a new seal unless I somehow find another part number that is compatible. Anyway, here are a few of my thoughts:
1. Use the old seal. My seals actually look really good, with no signs of wear, but egads, it makes me nervous not replacing a seal that is around the crank of all places - it must have some wear on it, even if it isn't noticable. This is probably what I will have to end up doing.
2. Use the new seal and assume that even though it doesn't have the ridge which obviously holds that darn thing into place, Yamaha realized this and is assuring me that the part will work just fine. I'd be real nervous about this though, because it seems like the seal could almost be yanked out without even cracking the crankcase (once I put it back together). Any thoughts?
3. It seems weird to me that this hasn't been an issue for anyone else. I mean, us xs11 owners aren't in the millions, but there must be enough of us that have cracked their crankcase for whatever reason, and then replaced these two seals as a simple precaution when they reassembled it. Seems like I could have found a mention of this problem on the net, these forums, etc.
Anyhoo, I'm going to wait and see if anyone replies with anything helpful, but am probably going to reuse my old seal, and be nervous about it for the next 4 years :-)
thanks!
Scott
thanks!
Scott
