i have a problem with my xs1100 idle mixture it is a bit lean,the airfilter is in place with on both side foamtape,the airbox is put thogether with a good rubber seal on the edge around,two carb vent. hoses are connected on the box and the crankhose too,and all rubbers between the box and carbs are correct fitting no leakage there,and at the bottom of the box there is a drain foamfilter in place.
now i'm asthonished that the engine keeps running when i totally close the intake hose,i noticed doing that that there was bilding up a vacuum when turning the trottle but where the heck is all the air leaking through the box,it is a puzzle for me
ther is only one cillinder getting the correct mixture number 4,there are cap's placed over the pilot screw's ,and the can't therefore turned to the correct mixture,i have to take them off to make the right turn out giving better mixture allthoug my repairmanuel advise me not to do that
![Confused](https://xs11.club/core/images/smilies/confused.png)
![EEK!](https://xs11.club/core/images/smilies/eek.png)
