28 mpg
  • DEmily
    • Jun 2003
    • 220
    • Kansas City, MO.
    I have never taken time to determine the mileage. I get around 125 miles or so before hitting reserve. I'll have to check?
    79 XS1100 f (BIGDOG)
    80 XS650 Special
    85 KAW 454 LTD
    Dirty Dan
      • 8054
      And to think I've been unhappy with 35 mpg! I'm 225 lbs+. I have logged about 40 mpg on a trip. Mine is a SG w/ 26K on the clock. The 50 mpg it gets keeps my XS650 on the road for the daily commute.
      • ARRON
        • Apr 2003
        • 28
        • neripis new brunswick
        my 79 special is getting 173 khm before the light comes on, i have carbs off a 82 maxim they are jetted wrong for my bike
        • thuffman
          • Aug 2004
          • 10
          • Montana
          resistor v. non-resistor caps
          Geezer, please enlighten me re: non resistor caps. Thanks, Tim.
          Tim
          1981 LH
          • macnut xj
            • Jul 2004
            • 135
            • Logansport, IN USA
            Yeah, I'm wondering about the resister caps too. I know the theory behind them (electronic "RF" noise suppresion, same as resistor plugs in your car), but I'm wondering how you check them. Is there a resistance check you can do on them? And where can you get non-resistor caps? I don't expect to ever mount a stereo on my bike, so I could care less about RFI issues.
            John
            82 XJ1100J
            "eXJunk"
            • graybird78
              • Apr 2003
              • 360
              • council bluffs iowa
              My bike's 80sg. get consistent 33-35 mpg 70 mph. I'm 6'3" and weight 250lbs. bike is a full dresser. fairing ,trunk side bags and carry 20lbs extra junk around.
              when you want something bad enough, don't let anything stand in your way, and don't take "no" for an answer. EVER
              graybird78
              80 sg (old faithfull)
              • randy
                • Dec 2003
                • 4521
                John, the caps should read 5K oms each. you can unscrew them from the end of the wire and then test through each one. While you've got them off, clip 1/2" off each wire before you screw the cap back on. The wire end is a common point of corrosion and will cause the same symptoms as fouled plugs, bad caps, dirty carbs,water in fuel, etc. etc.
                HTH
                Randy
                PS I get a consisent 40MPG on Swam Thing and the best I've ever gotten is 45. I hit reserve around 150/160 mi. This is with a mix of city/highway. I commute 40 mi a day to work M-F and then go home from NYC to PA 100 mi on the weekends.
                • Dennyz
                  • 1151
                  • Olympia, Washington
                  SF: 30-35mpg, jardine 4:2. 140 mains, K&N filter, drilled AB
                  SG: 32-38mpg, K&N filter, drilled AB, '78 carbs, stock exhaust
                  F: 35-42, 4:1, 145 mains, 45 pilots, K&N, drilled AB
                  If I go 80mph on the interstate, all three bike get around 30mpg.
                  DZ
                  Vyger, 'F'
                  "The Special", 'SF'
                  '08 FJR1300
                  • Geezer
                    • May 2003
                    • 2985
                    • Willamina, Oregon 97229
                    I'm still jealous. I can’t seem to get the Mongrel to do better than 32 MPG and it seems to do the best around 65~70 MPH. I thought the Vetter Windjammer would put a damper on the mileage but there was no noticeable change. I’m going to go through the carbs over this winter and maybe give it a valve job and cam chain but I’d be surprised to see much of a change.
                    I’m looking forward to seeing how my 70 standard resto-project does.
                    Geezer
                    • xsrider
                      • Dec 2003
                      • 49
                      • Cassadaga, NY
                      I can squeeze 140 miles out of my 4.0 gallon tank. highway traveling; that computes to 35mpg. Since it's a special [no gas guage] I rarely go over 120. I am usually looking for a gas station between 80-100 on the trip OD.
                      You guys are making me jealous. I did a cylinder & head replacement [and moved from KY to NC] and I am just getting "Bike" back together. New fuel lines and clutch spring shims are the last couple items to do.
                      tim correy
                      Cassadaga NY
                      80 Special "Big Nasty"
                      • randy
                        • Dec 2003
                        • 4521
                        You guys gotta remember. I went through this bike top to bottom, over 7 months. The only thing I didn't do was open the motor except for valve shims. I was lucky to get a motor that had 150psi compression on all 4.
                        In addition, I had all new or refurbished ignition, plug wires, caps, plugs, jets, filters, exhaust & re-pinned every electrical connection, blah, blah, blah.....before I ever turned her over. if I didn't have a good MPG value, I'd be pissed.
                        Randy
