battery sensor
  • xj11DAN
    • 37
    • oklahoma
    battery sensor
    On the Xj there is a battery sensor on the dash panel that will not go out unless you have a sensor in the battery, has anone tried to bypass this and go direct to the fuse block to get a signal? i think i can put a resistor inline and go to the fuse to get around it, when i changed the battery i destroyed mine trying to get it out of the battery, any suggestions? i hate to pay 25$ for a 2 c resistor.
    DN
  • Winterhawk
    • Jun 2004
    • 684
    • Missouri
    Some batteries come with the sensor included. I think aftermarket ones are $7.00. If your friends with a shop owner put in a used one.
    • Jerry
      XS & TRUE XJ GURU
      • 3023
      • Elma, IA.
      There is a write-up about bypassing the sensor at:
      Sometimes it pays to read the Tech Tips........
      Jerry Fields
      '82 XJ 'Sojourn'
      '06 Concours
      My Galleries Page.
      My Blog Page.
      • chevy45412001
        • Mar 2003
        • 1412
        • Jacksonville Florida
        Right on jerry
        I used the FIX from (jerry?)worked like a charm.Pics and description very easy to do. Even for me .I got awhole pack of resistors was under $2.00. I used 2.2ohm resisters still worked fine.From radio shck.
        1982 XJ 1100
        • xj11DAN
          • 37
          • oklahoma
          battery sensor
          thanks, I went to the local shop and they do not have one, so i got looking around the shop and i have the resistor and all the wire i need so i wil try to bypass the battery and hard wire in the pigtail. thanks.
          DN
