Compression test, leakdown test
  • Ken Talbot
    • 4251
    • Revelstoke, BC
    I finally got around to doing a proper compression test and leakdown test on the '81 Special I picked up recently. Yes, he one with the interesting wiring job on the rear signals. With the engine warmed up and the throttle held wide open, compression was as follows:
    #1 125psi
    #2 110 psi
    #3 75 psi
    #4 120 psi
    Hmm, that doesn't look too good. The bike seemed to run pretty good when I brought it home, but I suspect it may have been using a bit of oil. There was no noticeable smoke from the muffler, but the level was way down. When I fired it up tonight, I filled the carport with smoke. Not just a bit, but an incredible amount of smoke.
    Next step was a leakdown test. My tester calibrates at about 42psi, then the ranges are 10-40 (low), 40-70 (medium), and 70-100 (high) percent leakage.
    Test readings came out as follows:
    #1 39%
    #2 44%
    #3 100%
    #4 36%
    It was clear that the leakage on #1, #2, and #4 was past the rings into the crankcase. With the oil filler plug removed, that is where you could hear the escaping air. Carbs and muffler were quiet. However, on #3, it was obvious the air leakage was all back out through the carb. Both the muffler and the crankcase were quiet.
    Clearly, I have an open intake valve in #3 cylinder. My guess is this will probably be just a tight shim. That will be my next job - remove the cam cover and check the valve clearances - especially #3 intake.
    The oil burning tonight had me a bit worried too, but the results of the leakdown test make me feel a bit better. The fact that it didn't burn blue on the 4 hour ride home, along with reasonable compression and leakdown results on 3 cylinders tells me the rings are still okay, even if they are a bit tired. I'm sure the 4th cylinder will test okay once the valve closes properly. That makes me believe the valve stem seals are probably shot and tonight's smoke show was a result of the bike sitting for a number of weeks without running. The amount of smoke even seemed to decrease as the engine ran for a few minutes and got warmed up.
    More to come....
    Ken Talbot
  • Shuriken
    • 1093
    • Southwest USA
    That sounds about like my 80g. You should see it smoke. But it also smokes while running.
    I hate smoke.
    If you want to see smoke all the time out the tail pipe, use NAPA Engine Restore and Lubricant or any other product like Bard's No Smoke or Joe Blow's Fixit.....
    I tried that stuff in my XS11, XL500, a Honda Civic, and a Honda Accord. Each began smoking permanently thereafter.
    It's interesting to take the carbs and airbox off an XS11 and shine a flashlight into the intake ports and/or the exhaust ports with the headers removed - really shows the leaking seal problem.
    Ben
    1985 Yamaha VMX12n "Max X" - Stock
    Formerly:
    1982 XS650
    1980 XS1100g
    1979 XS1100sf
    1978 XS1100e donor
