Okay, I decided it's time to fix the sticking rear/front brake system on my XJ. The problem seems to be in the rear master/prop valve. I removed the rear caliper and tried to push the piston back in with c-clamp. Wouldn't budge! Spooge hole inside the master looked clean. I disconnected the line from the caliper and the piston pushed right back in. So I removed the master and prop valve and pulled them apart. I have yet to find anything wrong, but inside the master is some spots of brown varnish looking stuff. I blew thru all passages and washed everything out with brake parts cleaner, but it didn't touch this brown varnish. How do you get that stuff out of there? Do you just scrap it out as best as you can? And does anybody have a clue what might be the cause for the sticking brakes?
Thanks!
John
82 XJ1100J
"eXJunk"
Thanks!
John
82 XJ1100J
"eXJunk"
Good luck with yours.
they still work well. (Only did one so far Randy so I may still order the rest.)
