Looking to buy a new 4 into 1 exhaust header for my 81 xs1100. Any good deals out there?
81 xs1100 exhaust headers
You can buy a new 4 into 1 from Mac. Several retailers have them. Otherwise, you'll have to find one on eBay, swap meet etc.Marty (in Mississippi)
XS650E -
Exhaust
Your 1981 XS1100 uses the Special exhaust. Try to find those. Some of the aftermarket 4 into 1 exhaust are more trouble than they are worth - have to lose center stand, can't get to oil filter.Last edited by MPittma100; 07-01-2020, 06:33 PM.1981 XS1100H Venturer
K&N Air Filter
ACCT
Custom Paint by Deitz
Geezer Rectifier/Regulator
Stebel Nautilus Horn
EBC Front Rotors
Limie Accent Moves On In 2015
MikeComment
Aftermarket Exhausts
Here is a link to exhaust options courtesy of our friends across the pond.
1980 XS1100G "Dolly G" Full Dresser (with a coat of many colors
I think the best thing you can do for performance is to retain the stock down tubes and collector pipes. Cut the collector down-stream of the cross over. Leave enough for clamps. Fasten either Jardine muffs or Harley muffs.Skids (Sid Hansen)
Down to one 1978 E. Stock air box with K&N filter, 81H pipes and carbs, 8500 feet elevation.Comment
I have to say that 4 into 1s are overrated. I had a set of older (Chrome) Jardines on a 78E that had oodles of torque at lower and mid range rpms under throttle that would crap out at 95 to 100 mph. I had another newer set on a different 78E that suffered somewhat at lower rpms and also at 95 to 100. Jardine may have changed the baffles. Keep the oem down tubes if you can. They are double walled and look better.Skids (Sid Hansen)
