Shifting
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    Shifting
    when new I seem to remember seeing every dealer to ask about how hard my new 79 shifted. I needed to make truly positive shifts (forcing the up shifts in 2nd and 4th especially). They all said the same thing, these XS1100s have a tractor trans and need to be forcibly shifted through the gears.
    Little by little the shifting got a bit easier but always needed positive/forceful shifting. I even bought a pair of steel toe work boots to aide in the shifting.
    I sold it at 56K to a friend, he rode it to Mexico and also made two trips around the great lakes. Then he came to complain 2nd gear was slipping, I told him I had seen him power shifting the old bike and what did he expect, later 4th gear went out he still drove it daily.
    Now this 80SG I picked up requires very forceful shifting.
    My question a bike that has been ridden little, would it require positive/forceful shifting too ?
    At very moderate speeds, not getting on it much it shifts like a hot knife through warm butter without almost any sound.
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
    • 5062
    Have you ever had a false neutral between gears? The easier way to get it back into gear is to slow the speed and bring engine speed up accordingly. The dogs and slots would be moving near the same speed. By “moderate speeds” I assume it has more to do with rpms than ground speed. At higher rpm shifts, I think there is more of a difference in rotational speed between dogs and slots making it harder to shift. I just hope your suspicions about early failure are not correct!!!
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      Not worried that I'm heading toward tranny failure, the thought had not even crossed my mind.
      I just wonder if anyone (with a better memory than I) remembers riding a new or low mile XS11 ?
      I've not found a false neutral on this bike yet, the trans locks up in all gears very well.
      I am wearing big ol work boots for riding/shifting and the only time I notice I need to use force is under aggressive acceleration.
      I feel it will smooth out and get a bit easier, just wanted to compare notes.
      As I said I do remember seeing all the dealers and mechanics way back when I had my brand new SF, this seems familiar.
      76 XS650 C ROADSTER
      80 XS 1100 SG
        • 7942
        UD, mine shifts like butter.
        • MarkD
          • Jun 2013
          • 488
          • N. Michigan
          My first F had 7,000 miles on it, and my current F has 28,800 miles on the odometer. Both shift the same, fair to moderate pressure on the foot to shift, and have only had two false neutrals in memory. My experience has been that they are pretty easy to move from gear to gear.
          79 F
          1967 Suzuki X6 Hustler
          1973 Suzuki TM 125
          1979 XS1100 F
          2005 Kaw. Vulcan VN800
          1991 BMW K75
          • donebysunday
            • Oct 2012
            • 1737
            • New Berlin, Wi.
            Marty, how many miles and at what assault speed ?
            76 XS650 C ROADSTER
            80 XS 1100 SG
              • 8798
              You could try adjusting the clutch with a bit more pull (less cable slack), that will give more time to the gears to mesh smoothly. Worked for me, YMMV.
                • 7942
                I believe I'm at about 100,000 miles. I can push it pretty hard. I've had the bike since 10,000 miles. Somewhere along the way I replaced 1st, 2nd, 4th, and 5th gear on the countershaft. I did the washer move at the same time. I have to be very deliberate going into 4th gear, but I would not confuse that with forceful.
                Easy driving still requires paying attention while shifting into 4th. I can't be lazy about it.
                  • 2066
                  I have False Neutral
                  When I am speeding up aggressively on my SF, I sometimes miss 4th gear and end up in false neutral. It's easy to have it happen.
                  On my SG, it almost never happens, although the shift into fourth is the most soggy of all the shifts.
                  Note: The SF has the washer swap and the SG does not.
                  I suspect the possible causes of the sloppy SF shift are:
                  (1) The washer swap does something to affect the shift into 4th
                  (2) The SF has been abused too much- after all, first gear was shot when I bought it @ 15k miles.
                  • donebysunday
                    • Oct 2012
                    • 1737
                    • New Berlin, Wi.
                    I should have used the term deliberate shifting into second.
                    All the other gears do not require as deliberate shifting.
                    As per one of the first mechanics I asked about my then new SF, he said they have transmissions like trucks.
                    I disagree they might shift harder than some other bikes but as we all know they have a bit problematic second and forth gears.
                    On the other hand, Marty how many miles on your trans fix ?
                    76 XS650 C ROADSTER
                    80 XS 1100 SG
                      Also, suggest removing shift cover and check alignment marks of shift pawl assembly with tranny in second gear.
                      • donebysunday
                        • Oct 2012
                        • 1737
                        • New Berlin, Wi.
                        The washer swap allows more of the gears dogs to protrude further into the slots.
                        Putting an angle on the dogs and slots causes them to pull into the slots for a more positive hook up.
                        76 XS650 C ROADSTER
                        80 XS 1100 SG
                          • 2066
                          Of course.
                          I still wonder if there is any reason the washer swap would affect the 3-4 shift. It doesn't seem like it should.
                          • Dudenatz
                            • Jul 2011
                            • 71
                            • Zionill
                            This is something I have to watch, especially if I'm getting on it (her) hard.
                            (Wow, that statement can be taken in so many ways...)
                            -Jon-
                            1981 XS1100LH MNS #103 ("Dark Side")
                            Yamaha "Mini Cruiser" Windscreen, K & N filters, Iridium Plugs, ATK Fork Brace, LED T.S. Conversion, Bridgestone S11 Spitfires.
                            Otherwise all original, definitely a Survivor.
                            Previous:
                            1981 XS850LH MNS (R.I.P. 1983), 1982 XJ650 SECA TURBO, 1983 XJ650 SECA TURBO
                            Cage:
                            2K2 TB
                            "Light travels faster than sound. That is why some people appear bright, until you hear them speak."
                            • donebysunday
                              • Oct 2012
                              • 1737
                              • New Berlin, Wi.
                              I'll give that a try, Thanks, Done
                              76 XS650 C ROADSTER
                              80 XS 1100 SG
