Wire gauge for stator?
    • 8077
    I need to do rewiring. If someone reading this knows the gauge of the wires at the stator connector, I would appreciate that info.
    Thanks.
    • 7830
    8 AWG works well. Be SURE you have the same for the ground from Battery to frame, and frame to engine. ONLY USE AUTOMOTIVE TYPE WIRE! ( but YOU know that :>) )
    • mlew
      • Jun 2005
      • 226
      • Apex , NC
      # 8 is a bit big for the stator connections. It will be great for the starter. The XS charging system is good for 20A, # 12 wire is good for that.
      Slow down and enjoy life. If you are in that much of a hurry, you should have left eariler.
      Current rides:
      80 XS1100SG
      82 JX1100
      83 Venture Royale
      86 V-Max
        • 8077
        Thanks! I'm going to use aircraft wire instead of automotive. Aircraft wire is tin plated to prevent corrosion. I'm suffering corrosion in my wiring.
          • 7830
          Sorry, misread the thread...
          I use marine wire for the same reason. I can buy it at both West Marine AND a local auto parts store.
          • MPittma100
            • Aug 2011
            • 2359
            Wire
            Improve (poor) chassis grounds to direct battery grounds.
            Mike
            1981 XS1100H Venturer
            K&N Air Filter
            ACCT
            Custom Paint by Deitz
            Geezer Rectifier/Regulator
            Stebel Nautilus Horn
            EBC Front Rotors
            Limie Accent Moves On In 2015
            Mike
              • 8077
              Mike
              While I have ensured that is not my problem, I am going to do as you have directed.
              • MPittma100
                • Aug 2011
                • 2359
                Battery Ground
                Good deal. Doing so will keep future gremlins at bay.
                K&N Air Filter
                ACCT
                EBC Front Rotors
                Mike
