More Electrical Gremlins
  • Spartanman
    • Mar 2017
    • 17
    • Lake Odessa, MI.
    OK - fixed the last one on my 81 with dying suddenly. It was a loose connection coming out of the main fuse block.
    Now two new ones have come up at about the same time but I don't think they are related.
    First - when starting the bike, if it doesn't fire after the first try, I get nothing when I hit the starter a second time. Have to wait about 30 seconds and then it will crank again. If it doesn't then, another 30 seconds...etc.... Have a brand new battery and it cranks very strong, when it cranks. Now before, it would do this but only after 3 or 4 tries, and even then I would have to wait only about 5 seconds and it would crank again. Right now this is just an inconvenience, but obviously if this is going to get to the point where I have to wait.....for who knows how long...that would be a problem.
    Second - the tach. Doesn't work on startup. After riding for about 10 minutes, it starts working and then keeps working the rest of the day. After sitting overnight however, it then repeats the problem. I'm assuming this is a moisture issue somewhere, but if anyone knows which connection this is likely to be that would be helpful.
    As always, any input would be appreciated.
    81 xs1100LH
    75 Norton Commando
    If original fuse panel is still being used, it DEFINITELY needs to be changed over to the blade type fuse panel!....first order of electrical problem solving for these ole' bikes.
    • Spartanman
      • Mar 2017
      • 17
      • Lake Odessa, MI.
      Thanks - Is there a specific XS1100 fuse block that can be ordered?
      81 xs1100LH
      75 Norton Commando
        • 1566
        Yes,
        Len at XJ4Ever www.xj4ever.com is providing an XS1100 Fuse Box Kit. Has blade Fuse Box, Fuses, Wires and everything you need. It is a really slick Turn Key fix. It is all color coded too to match the original wire colors. Terminal connectors are already professionally assembled so that eliminates a problem point too.
        My 78' XS1100 E with the new fuse box
        note the Flasher Can is moved over to the left (battery side) of the bike and a patch cable is provided. The new fuse box mounts lower which provides much more room above & below the terminal connectors.
        Rather than use the insulated butt connectors provided in the kit Kurt used uninsulated with heat shrink. But to answer your question, Yes here is an option for a real nice Turn Key Kit. Call Len if you are interested. My bike sure runs better after we installed it just last Friday.
        • Spartanman
          • Mar 2017
          • 17
          • Lake Odessa, MI.
          Originally posted by JeffH
          Yes,
          Thanks for the info - that's a great website and has exactly what you described. However, can't order on line and there is no phone #. He says to "write" and let him know what you need. I hope that means e-mail as I sent him one last evening. Didn't get a response as of now. Does Len respond to e-mail or do I have to lick a stamp and send a letter? Any advice would be appreciated.
          81 xs1100LH
          75 Norton Commando
            • 1566
            He uses email. So if you sent Len an email he will respond back via email.
            At the email address listed.
            Normally 24 hours if not sooner.
              • 7817
              XJ4Ever.com is great. All parts are 1st quality. In my experience, no junk. He's not paying me to say this.
              • mro
                • 4276
                • Hayward, California
                That looks to be a pretty slick fuse box replacement.
                Back when I got my first XS I found that cleaning every ground and connection I could find made all the difference. Starter problem could be a solenoid going bad.
                  • 1566
                  Yes, a turn key replacement XS1100 Fuse Box Kit with about everything needed.
                  Relocating the flasher can to the airbox screw on the left side of the bike was EZ. That makes for a nice fuse box install with ample room for the wires and terminal connectors above and below the fuse box. Color coded wires too matching up with OEM wiring diagram. No more brittle 40 year old copper glass fuse holder tabs that snap off. BTDT, that's always fun when a tab decides to break off when you least want it to.
                    Oh yes Jeff, lots of fun and BTDT....once was enough after getting holder tab soldered back on, after which I switched to a blade type fuse panel.
                      • 1566
                      Yes indeed. This new Fuse Box Kit resolves all those issues and horror stories. A turnkey kit. Well made too. Saves hours and hours of fighting problems and finding parts that may or may not work. Comes with Step-by-Step instructions too. So no broken off side cover tabs or the usual things we snap and break in a DIY job. Step #1 says Disconnect Battery. Best to keep the sparks in the sparky container. Job takes about 2 hours. A little more for folks that don't turn a wrench much.
                      • Jerry
                        XS & TRUE XJ GURU
                        • 3023
                        • Elma, IA.
                        Will also mention that new battery cables are often in order. OEM stuff eventually has corrosion build up between the wires and connectors and causes a voltage drop right at the battery. Bike will fire much better if ignition system has full voltage available!
                        Jerry Fields
                        '82 XJ 'Sojourn'
                        '06 Concours
                        My Galleries Page.
                        My Blog Page.
                        • Spartanman
                          • Mar 2017
                          • 17
                          • Lake Odessa, MI.
                          Just finished the install. Very slick kit and the instructions were literally idiot proof as I just proved. Thanks for the tip. That website has a lot of interesting stuff.
                          81 xs1100LH
                          75 Norton Commando
