Hey there Jumper,
Well, at least that mystery is solved, you're running 79 carbs, which in itself is just fine. Just make sure you run those carb vent tubes up and are kept open, not clogged, possibly even a filtered cap on them if you're running Indy filters instead of the stock box. Many folks have had problems with poor performance, and came to find out their vents were clogged, either at the carb, the tubes going up from the vent ports, or even on the carb box where they attached, either plugged=wrong model/year carb box for carbs, or just crud/corroded closed. The new intakes will help considerably IF they were leaking to begin with. Good luck!
