Massive fuel leak
  • Incubus
    • 1003
    • Austin TX
    Massive fuel leak
    For those who will see pictures of this fuel leak on the national news tonight - don't worry, it's not Arkansas flood pictures. Even of the crests on the waves off flowing fuel are surf able.
    OK, maybe it's not quite that bad. But it seems that bad. I pour fuel in the top, it pours out the bottom.
    This is not a "please help me find the leak" post. This is a "crap, I've got a leak and it seems the parts are unobtainable" post. Maybe someone has an idea.
    The leak occurs on both sets of carbs, fright where the fuel feeds the carbs. The ridges on the fuel line T that connects the fuel lines and slides into the carbs have shrunk with age and gas leaks from there. Badly. I cannot find new carb T's.
    I've been to a couple of auto parts places looking for o rings that would fit the t's, but no luck. I know I am not the first to face this issue. How do I fix it?
    Patrick
    XS11F (Incubus, daily rider)
    1969 Yamaha DT1B
  • Incubus
    • 1003
    • Austin TX
    I am not sure why this posted twice. Maybe the forum deemed it an emergency?
    1969 Yamaha DT1B
      • 1590
      T fix thread. In the Repairs section under Carbs & Fuel
      The Sirius Consolidated T's are great. The best way to fix it, but more expensive. I've put these T's in 3 sets of carbs and they are a great upgrade.
      Yeah, been seeing the terrible flooding there along the Arkansas River and other places too ....... Awful to have your stuff flooded or washed away.
      • Incubus
        • 1003
        • Austin TX
        Thanks, Jeff. You are right. Those are not cheap. I'd like to find them for about half that....
        1969 Yamaha DT1B
        • Incubus
          • 1003
          • Austin TX
          I found a guy on Ebay who has one used one for sale. He wants $86.
          1969 Yamaha DT1B
            • 2160
            Alaskey just had the same problem:
            He had the same result that I normally have. The T's normally swell up within a few hours after fuel exposure, and will work just fine.
            You might be able to just turn off the petcocks and come back in a few hours.
            • alaskey2
              • Apr 2014
              • 271
              • 60940
              I sure did have the same problem. I did the o-ring fix about 4 years ago, then let the bike sit for the last three years. After it leaked all over I walked away frustrated, came back a few hours later and they swelled back up and no more leak! I did have to change the oil though.
              78 E
              • Incubus
                • 1003
                • Austin TX
                I'm not riding anywhere today anyway. I guess I'll give it overnight and see what happens.
                Patrick
                1969 Yamaha DT1B
                  • 7831
                  I used a nitril O ring set from Harbor Freight to fit one set of carbs. It DID work, but it was hard to insert the first time. I cleaned the old rubber off the "T", used 2 rings per side on the "T", and dielectric grease to ease them in.
                  • Incubus
                    • 1003
                    • Austin TX
                    WEll, after a night of exposure to gas, the T's did seem to swell a bit. The leak is more of a seep, right now. Still enough to really stink up the garage and front room. I need to go to Harbor Freight anyway, is I'll look for some nitrile orings. Eventually I will need to go the correct repair route, but I need to see if my XS11 is the bike that will be my regular rider this year. I may do this season on my VF750. Less power, but more nimble for city traffic.
                    1969 Yamaha DT1B
                      If this is one of your F standards, you should also deal with the leaky needle and seat in the fuel valves.
                        As I'm sure you've seen in the past on here, there's been more than one member who had there home, etc. go up in flames from an XS11's leaky fuel situation. I highly recommend the bike be parked outdoors till that leaky fuel situation IS resolved.
                          I'm sure Diver Ray, 3Phase and a few others here on the site remember and can verify these fire incidenses took place!
                            • 2101
                            Fuel Tee Repair Thread
                            Here's a link to the fuel tee repair.
                            My version starts on post #8 and has been flawless for three years running.
                            While you have the carb bank apart replace the B-Fly shaft seals also.
                            • Incubus
                              • 1003
                              • Austin TX
                              Rather than having my house explode, I drained all gas from the bike and I have separated the carbs and tank from the bike. I've been all over these carbs the last few days and I am confident I have solved all leaks except the T's. Despite the fuel flowing everywhere in my garage, the inside of my airbag was bone dry. The second time. The bike actually sat with fuel in it for a year (I know) and never leaked. When I drained the bad gas and put in fresh gas it leaked everywhere. So I believe my petcocks are still holding vacuum and my fuel valves were not leaking until the new gas melted the crap that had formed.
                              I rode this bike for years (except the last one) without a single issue. It always started, always ran and never leaked. I even had the same battery the whole time. I need to get back to that.
                              BTW, I once tried to change the b-fly seals on a set of these carbs. Never, ever again....
                              Patrick
                              1969 Yamaha DT1B
