OK, I'm looking for some guidance here. I changed the oil on my cycle on Tuesday. After installing the new filter and refilling with oil I started it and everything sounded fine. I rode it for a little while and then, about 10 blocks away, it started running really rough and smoking badly (white smoke).
I parked it in the garage and the next day there was a large puddle of oil. I left it alone, starting it a couple times and noticing more smoking, just not as bad. Today I decided to take it to the bank to see if I could run it for a while and see an improvement. I got to the same spot as Tuesday and it started smoking badly and running rough, followed very quickly by a smoothing of the engine and the smoking stopped.
I rode it to the bank to make a couple deposits and when I came out there was a small puddle under the bike again. I rode it home and it ran great all the way but, after parking it, I again noticed the oil dripping. This first picture is after it was parked for about 30 minutes.
As you can see, there is another puddle. The bike is running great but obviously this worries me. I took a couple pictures of areas that are wet.
What is this housing? It's hard to tell but it was wet with oil right where the arrow is pointing.
Also, I found a hose that was dumping oil. It was just dripping out but I'm not sure what this hose is.
Here's where the hose is connected:
And although you can't see the end very well, it just hangs freely and is dripping oil.
When I changed the oil, there was very little that drained out which leads me to believe the cycle may be using oil, whether by leaking or burning it. I haven't noticed puddles under this bike for over two years, though. It just started after I changed the oil.
Can someone help me out and explain what I'm looking at in these pictures? Should I be as concerned as I am about this?
Thanks for any help you can get me.
