Is it possible that the fuel can leak out from the tank and make its way into the crankcase oil? Ive had it come out of the air box before when pick up coil went out. I went for a ride and when I got rpm's up, the bike revved up like it had the clutch pulled in. It does that in each gear when I try to accelerate quickly. I changed the oil and filter and it smelled like some gas in the oil. After the oil change it still did it not as bad. The next day it was back to doing it like it was before oil change. Do I need to rebuild the petcocks or is there another issue?
Thanks in advance
Thanks in advance
