Follow up to Valve Cover Gasket Question
I need to remove my valve cover to make sure my Cam chain did not slip off the sprockets while the old CCT was removed. In this process, the bike rocked off the center stand, moved, sat on its side stand, and moved some more, all with the CCT removed. I just want to make sure I do NOTHING wrong when having the valve cover removed.
Questions for this post
Is it bad to rotate everything by hand while the cover is off?
What should I be looking for?
When installing the ACCT, I should have the crank lined up on "C" correct?
Any more info helps.
Thanks guys
Thanks guys
