Needle Float Assembly
  • CivilPenny
    • Sep 2017
    • 26
    • MI
    Did a test on my float assembly’s and two of them checked out bad. Replaced them with what was supposedly original OEM Yamaha parts. Got them and they are a little different. Still jetted to 2.0, but the needles are different and have different tapers, and heights. Gonna slap em in anyway and see how they run.
    79 SF Special
    80 Special
    Bike will NEVER run correctly unless Genuine Mikuni and in ORIGINAL Yamaha/Mikuni packaging. Having different tapers and lengths will especially NOT work!
    • CivilPenny
      • Sep 2017
      • 26
      • MI
      So where the HELL do I find them?? I’ve looked everywhere and even the damn dealer can’t supply me with MIKUNI ones
      79 SF Special
      80 Special
        • 2160
        Opposing viewpoint
        You can't go wrong with Mikuni float needle valves, but I have K&L in my 4 of bikes and I am satisfied. I did buy the needles and seats together as an assembly, and I did need to readjust the floats significantly.
        One note of advice with the K&L, make sure the needle valve wire that goes around the float tang is not bent. If it is, straighten it out. Otherwise, the spring in the needle valve is pre-compressed and it behaves differently.
        • speedlimit85
          • Jan 2017
          • 454
          • Gainesville, Fl.
          Partzilla.com
          80 G
          • MPittma100
            • Aug 2011
            • 2359
            Needle valves
            Relying on dealers is most often a waste of time. These bikes are too old for them. All the information you need for any XS1100 or XJ1100 is tight here at XS11.com. Mikuni parts are not cheap, but they are what you need to use.
            Partzilla.com
            https://www.partzilla.com/product/ya...0b62d5fc935085
            Jetsrus.com
            http://www.jetsrus.com/individual_parts/007_503_su.html
            1981 XS1100H Venturer
            K&N Air Filter
            ACCT
            Custom Paint by Deitz
            Geezer Rectifier/Regulator
            Stebel Nautilus Horn
            EBC Front Rotors
            Limie Accent Moves On In 2015
            Mike
              • 1261
              • Peachtree City, Georgia.
              http://www.jetsrus.com/index.html
              JETS R US!
              These guys offer GENUINE MIKUNI and "EQUIVALENT".
              NEVER had a problem with ANYTHING these guys have sold me....
              1982 - CBX1000 - Honda
                • 5073
                Kurt, you have 8 bikes? You must have a big garage!
                  • 1261
                  Stuffed in like sardines in a can.
                  YES, I have eight(8), plus the remains of a few others stuffed into the garage
                  NO, the garage isn't big it's basically a two-car with a 12' single door, but I have 'em stuffed in there like sardines! I can get my favorite XS11 (Duck) and the FJR out with relative ease, the others require me to nearly empty the garage to get to them..
                  The two-wheelers also share the garage with a '78 Trans Am 455. The car isn't exactly a Prius so it's footprint is rather large too..
                  • mack
                    • 2411
                    • Ontario, Canada
                    Jets R Us
                    I haven't had much luck with Jets R Us. Specifically ordered mikuni assemblies and got K&L. Sent them back and they wouldn't issue me a refund. If your seats are good then just order the metal on metal needles from "mikes XS".
                    K&L is just a packaging company. They order stuff and put it out to tender then package what the lowest bidder sends them. They could be from Taiwan, chec republic, mexico, china who knows. Even in the packages there is no quality control in the spring tension from needle to needle.
                    mack
                    79 XS 1100 SF Special
                    HERMES
                    original owner
                    81 XS 1100 LH MNS
                    SPICA
                    78 XS 11E
                    IOTA
                    https://youtu.be/wB5Jfbp6SUc
                    https://youtu.be/RaI3WYHSuWA
                    Frankford, Ont, Canada
                    613-398-6186
