Painting Engine Cooling Fins
  • Ian_J
    • Jun 2016
    • 6
    • London, Ontario, Canada
    Hey folks ... I have an 81 Eleven Special with the section of black cooling fins. I want to change that to a solid silver/aluminum color.
    Any recommendations on the paint make/color to use?
    I tried stripping the black with Aircraft Remover but it did not touch it. The black will be painted over!
    Cheers!!
    .. ij ..
    .. ij ..
    • 7736
    You can have the paint soda blasted to remove the old paint, and use a good, high temp paint to re-coat. You will want to use self etching primer on it first, as this will keep the aluminum from oxidizing and peeling the paint. I would NOT just put more paint on top of what is there, as it adds a layer of heat retention to the barrels.
      Ian, for an excellent quality paint that does NOT change color from heat, I highly recommend Duplicolor Aluminium DH1606. Good for 1200degrees. Your local NAPA sells the Duplicolor brand. Just an FYI, I used this to touch up one lower exhaust where it meets muffler, just below the heat shield. Did this some 7yrs. ago, and still looks like the rest of pipe with no color change.
      • Ian_J
        • Jun 2016
        • 6
        Thanks for the feedback fellas!!
        Just what I needed to hear!!
        I have stripped and repainted the tank and side covers, and have been wet sanding and polishing the aluminum casings. I prefer the look of an engine being a uniform color.
        I had a 79 XS1100 Special back in the day and would like to get back to that look.
        Thanks again!
        .. Ian
        .. ij ..
        • Rasputin
          • 3189
          • Lacombe, Alberta, Canada
          Totally yes on the self etching prime or all of you paint will fall off. Happened to me!
          2-79 XS1100 SF
          2-78 XS1100 E Best bike Ever
          • Ian_J
            • Jun 2016
            • 6
            Do I need a high heat self etching primer prior to using the Dupli Color DH1606?
            My paint rep says no but I would like to hear from someone who has done it.
            Thanks!!
            .. Ian
            .. ij ..
              • 7736
              A LIGHT coat of any self etching primer should do it. I usually use the best I can find, about $20 per spray can in the US. This is made by S.E.M. paint here.
              • Ian_J
                • Jun 2016
                • 6
                Thanks Ray!
                .. Ian
                .. ij ..
                  Thanks!!
                  .. Ian
                  Paint rep. IS correct......NO primer prior to using DH1606.
                  • MPittma100
                    • Aug 2011
                    • 2359
                    Paint
                    Yamaha painted the fins black to enhance heat transfer. Many other automotive manufacturers did and still do the same to their engines. JAT
                    1981 XS1100H Venturer
                    K&N Air Filter
                    ACCT
                    Custom Paint by Deitz
                    Geezer Rectifier/Regulator
                    Stebel Nautilus Horn
                    EBC Front Rotors
                    Limie Accent Moves On In 2015
                    Mike
