No ignition at all
  • TADracer
    • 1417
    • Kenner, Louisiana USA
    Thanks guys, I really appreciate the help.
    Mike Giroir
    79 XS-1100 Special
      Originally posted by TADracer
      I guess next I will change out the Ign. switch and check the connectors at the TCI
      A problem I have run into a couple of times is with the 4 wire connector at the TCI. The connectors in the plug get stretched out and the signals from the pick up coils can be interrupted. The connectors can be carefully removed from the plug and squeezed tight with a pliers then reassembled. I do one at a time so they go back in their correct location. HTH
