Things to get the bike running again
  • Toolmaker Tim
    • 671
    • South Bend, Indiana
    First question is about the engine oil. I have seen supposed wet clutch friendly synthetic oil for sale. Has anyone tried it. I seem to remember dino juice was the only way to go in these bikes. Has that changed? Next is going to be the clutch. It has been sitting held together by the springs for several years now and I know the plates are stuck together. Usually I was able to get the plates to seperate by dropping it into first while putting front wheel against the tire on my Jeep. I figure it may need a bit more help this time. Should I just suck it up and pull the engine cover and disassemble the clutch? Is there a better way?Finally, I have a King/Queen seat. The old joints don't like to be stuck in one position for any length of time. Who has seatcovers for a reasonable price (to be determined) to get back to a stock standard shaped seat.
    1979XS1100SF
    K&N's and drilled airbox
    Jardine 4in1
    Dunlop Elite 3's
    JBM slide diaphragms
    142.5 main jets
    45 pilot jets
    T.C.'s fusebox & SOFA
    750/850 FD mod.
    XV 920 Needle Mod.
    Venture Cam Chain Tensioner
    I suggest if oil level is down a bit from full, add a bit of Dextron II or III, run a few min. in neutral, then work lever a few times putting it in gear.......headed a safe direction of course. Just don't use F type auto tranny fluid. Once it's working correctly, drain oil/change filter, add new oil back to FULL level.
    • Toolmaker Tim
      • 671
      Clutch
      Ok, I need to change the oil anyway. If I need to I can always suck some out with a siphon. How about the oil? Haven't looked, but I always used Castrol 20w50 before, but if the synthetic stuff is better I will use that. Thank you.
      1979XS1100SF
      Jardine 4in1
      Dunlop Elite 3's
      142.5 main jets
      45 pilot jets
      750/850 FD mod.
      XV 920 Needle Mod.
        • 9981
        House brand (Super Tech I think) 20/50
        from Wally World is all I ever use
          • 2138
          Seat Covers
          This place is not the cheapest for seat covers, but they make very good replicas:
          • Toolmaker Tim
            • 671
            Seat
            Thank you for the link Mike. After looking at the interchangeable parts post by Crazy Steve, I have discovered I have a 80-81 seat on a 79SF bike. That explains the large gap in the back. Was looking for a replacement seat on fleabay last night and got sticker shock. This bring the bike back may be harder and more expensive than I realized
            1979XS1100SF
            Jardine 4in1
            Dunlop Elite 3's
            142.5 main jets
            45 pilot jets
            750/850 FD mod.
            XV 920 Needle Mod.
              Hi Tim,
              Shop around on here for a seat. Fleabay prices are always too high.
              Recover a cosmetically poor seat as long as the pan is in good shape.
                • 7817
                Tim,
                I'll be back home later this week. I MAY have an older special seat in storage. If so, it's gonna be cheap. I'll PM once I know for sure.
