Rear brake lh midnight
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    I have a sticking rear brake on DARKHORSE LH, must be the spooge hole again or bad batch of borsch (brake fluid) ?
    I found small rust flakes and rust colored dust in the MC, disassembled cleaned twice now doing it again ? I'm thinking maybe some seal is damaged or ?
    ADVICE PLEASE
    Also best place to get a seal kit ? Partzilla $42.99
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
    Rebuild/clean the system, master and caliper. Use DOT5 when you put the new fluid in. Silicone base, doesn't absorb water, won't take off paint. Bad news, you CANNOT mix it with any other fluid.
    This is what I had done on my '79's, and never had brake problems after that. JMHO
      • 735
      LH rear Master Cyl
      Done,
      I have not been able to find a rear master cylinder rebuild kit for my XS1100LH.
      Not even an after market one....But fortunately I was able to save it by just cleaning it. Who knows how long that will last before the seals need to be replaced. From the research I have done on here, you may have to delink the system and go with an older more readily available system, ( SG or LG), or possibly convert to an XJ1100 MC. If you successfully locate a source for a rebuild kit, please let me know!
      Thanks,
      Bob
      • donebysunday
        • Oct 2012
        • 1737
        • New Berlin, Wi.
        Done,
        Thanks,
        Bob
        Thanks Bob !
        I had checked the caliper but only glanced at the diagram for the MC. Now I checked on the XJ1100 too and it looks like the same MC and same problem, unavailable.
        Hope I can get the same results you did with cleaning again instead of wire brushing the steel rusty part I'll use a wire wheel and final soaking in Evaporaust, fingers crossed.
        Good Luck !
        76 XS650 C ROADSTER
        80 XS 1100 SG
          For the MC seals, check the bore size on other Yamaha bikes. They usually use off the shelf sizes for seals, as it saves money if they work. Try and find a fitch or digital Yamaha parts list for your bike, and then look for the same size parts for a newer model.
          • donebysunday
            • Oct 2012
            • 1737
            • New Berlin, Wi.
            Thanks Ray !
            Providing I find a way to cross reference I will provide the part numbers, unless someone has done this before and has the part numbers.
            I would not want to be repetitious
            76 XS650 C ROADSTER
            80 XS 1100 SG
            • andreashweiss
              • 951
              xs1100 rear brake system,
              I can supply one complete xs1100 rear brake system for $75 shipped by us priority mail, caliper, pads, caliper bracket, brake lines, master cylinder, used functional, from a special model, first pm by date/ time can have it. thanx andreas
                If you have the NLA seal part number, look at the last two digits. If it's an -00, try a -10 or -20 instead. Usually numbers are the same part, just different color, or a "fix" by design change, but will work on the older models.
                  That seems very reasonable for the complete system Andreas. (But I am not the one looking).
