fork bushings
  • dansmith65
    • Aug 2017
    • 141
    • Kootenays, BC , Canada
    fork bushings
    Does anyone know where to find fork bushings for an 80SG? Here are the measurements my mechanic gave me:
    Upper: 37mm OD, 1.5mm thick, 14mm wide
    Lower: 35mm ID, 1.5mm thick, 20mm wide
    I can get by with the one's I have, but he suggested I replace at least the lowers, if I can find them.
    80 SG Canada
    • 8077
    • dansmith65
      • Aug 2017
      • 141
      Thanks Marty. I suppose I have to call to get the right size? All I could find listed was http://traxxion.com/product/fork-out...-oem-fob37152/, which say's it was for my bike, but isn't the same size as the mechanic measured.
      Also, I assume "outer" means "upper"; is that right?
      80 SG Canada
        • 8077
        I don't know if outer means outside the fork tube, or inside the fork lower. I've had good luck with them over the telephone. Call them. We're EDT.
        • dansmith65
          • Aug 2017
          • 141
          Thanks. I got some lower bushings ordered. The measurements were a little different than I had, so I hope they fit. Will update this thread if they don't. They also measure the OD of the lower/inner bushing instead of the ID, like mine was measured, so it's apparently supposed to be: 37ODx20x1.5.
          80 SG Canada
