View Post
Catastrophic 2nd gear failure!
"Project XS11"
teardown
If the motor is already out why not split the cases and do an inspection and clean up everything. Switch your big end and crank shells to blues while your in there and blow out your crank passages and all the other oil galleries. It will only add one day on the rebuild. Great opportunity to clean the cases inside and out. All your top end components are probably in good shape so all you'll need is a gasket set. Andreas sells his tranny components in complete sets, but make sure to blow out the oil passages. I treat them like gun barrels and put them and the gears in my ultrasonic cleaner before reassembly and installation. Don't forget the washer swap before you install second again.mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186
Thanks!
Thanks Mack for the great advice (btw your LH is beautiful!), and thanks to everyone else for their ideas and suggestions as well. And based on everyone’s feedback, I feel that this project is over my head, so this SF has migrated to a new home; It has been rescued by another XS11 enthusiast who is looking forward to the challenge of saving this endangered species. And now I can get back to my LH project and hope it turns out half as nice as Mack’s!Bob's Bikes:
"Project XS11"
At least
it didn't get junked. I'm saddened though because these power plants are easy to work on. You would have enjoyed tearing it down and seeing why "keep it simple" applies to these motors. How they transferred the torque efficiently in different directions to accommodate the shaft drive. It really is a marvel.The Haynes manual is very good to explain the "why", but the Clymer's have better pictures. Read together, they compliment each other perfectly. Best of luck brother!mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186
