Grips
  • Bish
    • Mar 2013
    • 15
    • Nottingham, NULL, UK
    Grips
    Hi Does anybody know the part number for grips for a SF also size and where best to get a pair , Thanks Bish
    79 SF
  • robbo
    • 106
    • Aldershot. UK
    According to CMSNL 2H72624100 is the part number.
    Genuine Yamaha grips....Pricey!!
    https://www.ebay.co.uk/itm/YAMAHA-DT...QAAOSwm~dadEHE
    Aftermarket
    https://www.ebay.co.uk/itm/Yamaha-RD...gAAOSwA3dYZNuq
    Bar size 7/8"
    Hope this helps
    Rob
    Rob
    XS Eleven SF
    Could this be the finest Triumph Bonneville ever built ?
    (Cycle January 1979)
      I think mine are Bikemaster foam grips. I like them because the outside diameter is a little bigger and they are easier to resist the spring torque of the throttle. The narrower grips pull on the palm of the glove and can cause annoying wrinkles.
        I have fat aftermarket grips on two bikes and skinny factory grips on three of my bikes.
        I like the skinny grips because I can get to WOT more easily.
          Bish, right throttle side housing COMES with new grip installed from Yammies factory, and having gripping flutes on plastic throttle housing, is difficult to remove grip. Left side is just an internally smooth grip.
            Bish, for left side grip, no matter grip choice, either use Grip Glue(which most motorcycle retailers have in a tiny tube), or better yet, purchase a small can of White Rain or Final Net hair spray and spray left side of handlebar. Immediately install left grip and let sit overnite. Gives the best grip adhesion I've ever come across and is cheap. Learned this many decade ago when involved in the moto-x world.
              I like these.
              Biltwell Renegade
              • DeanR
                • Jan 2005
                • 1499
                • Finger Lakes NY
                BMW grips $13.89 ea L/R - #32721458395/6
                Progrips #714 $9.26 pr
                Oury Road Grips $12.30 pr
                80 SG
                81 SH in parts
                99 ST1100
                91 ST1100
