front brake caliper assembly SG
  • DeanR
    • Jan 2005
    • 1493
    • Finger Lakes NY
    When does the piston get reinserted? Before or after installing the PIA rubber boot/retaining ring? Neither way seems to be working for me.
    Also, bikerphil has previously told me how to remove the brake switch from the front m/c (via the small release hole/tab) but now I don't know how the heck the rubber boot is removed without wrecking it, to access the circlip.
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
    • 8797
    Put the caliper piston in, then the dust boot, then the retaining clip. I know the retaining clip can be a PITA and may take several tries.
      • 2066
      There is no circlip to remove the brake switch from the MC.
      After you peel back the rubber boot, look for a hole in the circumference of the plastic housing. Insert a small screwdriver or awl to release the spring tab, and pull out the switch.
      • DeanR
        • Jan 2005
        • 1493
        • Finger Lakes NY
        yep, but got it Phil. Problem is the clearance by the caliper body/base.
        M/C innards are held in by the circlip which is hidden by that damn rubber boot.
        80 SG
        81 SH in parts
        99 ST1100
        91 ST1100
          • 7765
          Have the "open" end of the clip close to the body, and work it in starting with the least clearance. Also, put just a smear of brake fluid on the clip to lube it so it will slide over the rubber easier. I use a paper towel with a few drops of fluid on it and wipe the clip.
            • 2066
            Ohhhhh... that clip.
            I always tear "that damn rubber boot" and have to buy a rebuild kit just to get a new boot.
            • DeanR
              • Jan 2005
              • 1493
              • Finger Lakes NY
              Just got the rubber boot off the circlip of the m/c without ripping it !!
              Innards had some funky stuff in there, but everything wiped right off and looks like new.
              Next question .. I read somewhere that you should maybe remove the white reservoir from the base and clean underneath. Not sure how to do that or even if that's a good idea, as it is so solidly connected, almost as a single unit. If it were to separate, then how to get it back together as solidly?
              Also, I've gotten the inside of the reservoir bone dry a few times, and each time there is moisture present the next day. What's the deal with that?
              80 SG
              81 SH in parts
              99 ST1100
              91 ST1100
                • 7765
                If it isn't leaking, I would NOT remove the reservoir. The moisture is because the brake fluid loves water!
                  • 7941
                  The packing under the reservoir is not listed in the parts breakdown. That o'ring will have to be matched by dimension and be designed for brake fluid. Reusing the old packing is inviting a leak.
                  • DeanR
                    • Jan 2005
                    • 1493
                    • Finger Lakes NY
                    Is this the correct install order? I neglected to take note.
                    Lots of pictures in the threads have vanished, as we all know.
                    So Marty, you would also leave the reservoir alone as DiverRay said?
                    edit .. I just went to attach the picture, and don't see the attachment option anymore. Can't we post pictures now?
                    80 SG
                    81 SH in parts
                    99 ST1100
                    91 ST1100
                      • 7941
                      Ray's advice is good. That being said, if the reservoir is nasty, I pull it off. The packing should be replaced at that point.
                      I'm seeing all the Photobucket pics. I'm using an app on Chrome that fixes it.
                      • DeanR
                        • Jan 2005
                        • 1493
                        • Finger Lakes NY
                        oops, I forgot the pain in the ass photo posting process here, so I guess you guys won't see my master cylinder parts.
                        Photobucket didn't seem to be working as it has either.
                        80 SG
                        81 SH in parts
                        99 ST1100
                        91 ST1100
