Mid/Final Drive Oil
  • MPittma100
    • Aug 2011
    • 2359
    Mid/Final Drive Oil
    Yamaha service/owner manual suggests 80W oil for the drives. I found a Redline product that is 80W. It is a synthetic blend. Redline part number is 42704. Not readily available in stores, but is online at several places.
    Has anyone used this oil?
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
    • 7942
    Mike,
    Why mess with success? 75W140 Mobil 1 or Royal Purple works great. I'm not switching.
      Being a synthetic oil, 75-140w IS equivalent to 80# conventional HP oils.
      80# synthetic does NOT have the needed 'cling' factor, therefore, more heat, which is from MORE friction WILL eventually result. Have noted a couple cases where final drive/lube end results were not good, especially on LD rides. Both had used 80# synthetic of high quality.
        • 7765
        I've used 70/140 Redline for the past ...years. In all my machines it works, and the final drive does NOT get as hot as it did with ANY 80W.
          • 9980
          75w140 full synthetic is what's used in those touchy Ford truck diffs. That's why I started using it. If it can keep those from grenading it's good for ANYTHING.
          Been using it for years without issue. Change it out every spring.
            Very true BA80, as my F-350 diesel's differential is tagged specifically for 75-140w synthetic.
              To original reference, I found from testing differences real world by riding Interstate 70 west 130mi. to Green River, Utah, checking diff. temp. using infared. Then, returning home, changed final drive lube(80# conven.), replacing with Royal Purple 75-140w synthetic lube. Rode same Interstate run again, same ambient outside temps(102F). Checked final dr. temp. at same stop/turn around. The synthetic 75-140w allowed final drive to run those constant interstate speeds 15deg.F cooler. Less friction= less heat.
                • 3239
                What was the temp of the FD housing when you checked it? 15 deg is a difference for sure, just wondering if it’s between 155 and 140 deg, or 215 and 200, that kind of thing.
                I ran 75w140 syn in the XS based on what I read (same info, you had done a temp comparison) from another post you made years ago Brant. No need for anything else, IMO.
                ZRX1200
                Seca 750
                  That testing was done some 5-7yrs. back. So that combined with 'old age'n' treachery'.......CRS Bonz. I just know, that difference in temp. readings more than convinced me those lower final drive temps. using 75-140w synthetic lube oil as opposed to conventional EP 80# was a result of less gear/bearing friction. I also use the same syn. in middle drive. Basicly just sayin', the use of syn. lube of the 80# variety instead of 75-140w syn. WILL eventually create bearing/gear issues that are not good!
                    • 5062
                    Originally posted by motoman
                    (snip)Basicly just sayin', the use of syn. lube of the 80# variety instead of 75-140w syn. WILL eventually create bearing/gear issues that are not good!
                    Just wondering...Does the final drive liquid even touch the bearings?
                    • MPittma100
                      • Aug 2011
                      • 2359
                      Final Drive Oil
                      Yes, it touches the bearings within the final drive assembly.
                      https://www.partzilla.com/catalog/ya...0g/drive-shaft
                      K&N Air Filter
                      ACCT
                      EBC Front Rotors
                      Mike
                        • 5062
                        Ha! Of course there are bearings in there. I don't know what I was thinking, or NOT.
                          • 3239
                          Skids, you gonna bring that shaft drive ST 1300 of yours to the Colorado rally again this summer?
                          ZRX1200
                          Seca 750
                            • 5062
                            I don't know of the rally yet. Both of my xs11's seem to be running fine now and I might bring one of those.
                              • 3239
                              Ok... You live in Colorado... Retired... live an hour from the rally site... Rally info is in the Southwest section.
                              Hope you can make it!
                              ZRX1200
                              Seca 750
