For a few years now, I have been upshifting by applying upward pressure on the shift lever and quickly backing off the throttle without using the clutch where it falls into the next gear. The method has worked fine-until now. My tranny started to rebel against this method today and is shifting harder. Does this clutchless shifting do damage?
clutchless upshifting causing issues?
"Galaxy" 1982 XJ1100J, 1983 XV handlebars, new fusebox, homemade SS wind screen and SS muffler heat shields, homemade grab bar extension and luggage rack. XS750 140 mph speedo, '81 Venture oil cooler, V-Max ACCT, Yahman YICS Eliminator, 1st and 2nd gear Dremel fix.Tags: None -
Can if continued. It can prematurely round off the engaging 'dogs' of each gear and end up causing transmission not staying in gear with the notorious jumping in and out of gear. This will mean you'll have to remove lower tranny shaft assembly, remove gears and dremal- grind the dogs back square-edged. Learn to shift SMOOTHLY using the clutch and save yourself ALOT of unnecessary work!For a few years now, I have been upshifting by applying upward pressure on the shift lever and quickly backing off the throttle without using the clutch where it falls into the next gear. The method has worked fine-until now. My tranny started to rebel against this method today and is shifting harder. Does this clutchless shifting do damage?81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top. -
I've been upshifting without using the clutch for years. Done properly it will cause no issues.power shifting is no more damaging than any other method.Can if continued. It can prematurely round off the engaging 'dogs' of each gear and end up causing transmission not staying in gear with the notorious jumping in and out of gear. This will mean you'll have to remove lower tranny shaft assembly, remove gears and dremal- grind the dogs back square-edged. Learn to shift SMOOTHLY using the clutch and save yourself ALOT of unnecessary work!
It will cause damage if gears are continuously missed and grinding occures. 21st and 2nd gears are a known issue with the XS/XJ no matter.Last edited by BA80; 12-27-2017, 05:53 AM.Greg
'Done properly' IS the key phrase! By XJkid's statement, he is NOT following the proper sequence(absolutely no shifter pre-load!)I've been upshifting without using the clutch for years. Done properly it will cause no issues.power shifting is no more damaging than any other method.
It will cause damage if gears are continuously missed and grinding occures. 21st and 2nd gears are a known issue with the XS/XJ no matter.Last edited by motoman; 12-27-2017, 05:09 PM.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Engines is engines and gears is gears. I learned to ride Limey shift ('64 Bultaco) on my first bike, then relearned all over again for modern bikes, cars, trucks, split axles, whatever.
You need some experience to get the feel for the engine and drive train, then figure out what makes it a happy shift with a smooth change, not an unhappy shift with bent shift forks, stripped gears, a 'sploded transmission and/or a blown differential. Some of them are more than a little expensive and can be very difficult to rebuild afterward when you mess up. Don't do that.
♬Comment
"Galaxy" 1982 XJ1100J, 1983 XV handlebars, new fusebox, homemade SS wind screen and SS muffler heat shields, homemade grab bar extension and luggage rack. XS750 140 mph speedo, '81 Venture oil cooler, V-Max ACCT, Yahman YICS Eliminator, 1st and 2nd gear Dremel fix.Comment
Interesting. I've always assumed that power shifting was okay, just not down-shifting clutchless. I don't do it anyways, but still a good tid-bit to remember. Might I presume this info would not necessarily apply to more modern bikes with sychro-mesh and slipper clutches?1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
This ^^^^^ is key to shifting clutchless on just 'bout anything.
Been there many times, car, truck, motorcycle, whatever, where cable or linkage broke or come apart in the middle of traffic, woods or too close to the job or home jus' figger it out and ride her on in
AND like Greg states been doin this for years on my all my bikes with no ill effects1980 XS1100G "Dolly G" Full Dresser (with a coat of many colors
Preload to my mind is putting pressure on the shifter/gears anticipating that a reduction of power by chopping the throttle will cause the preload (pressure/tension) to allow the gears to change.
I.E while under power/load there is not enough tension/force to make gears change. However when the teeth are not under a drive load there is enough tension to make the change.
Simply taking up the slack on the shift return spring is exactly that, taking up the slack. It is not applying pressure/tension in the gear changing sense.
I will do clutchless shifting sometimes when short shifting up through the gears. Otherwise it seems more of a potential for problems than a benefit to performance on the street. YMMV.Howard
ZRX1200
Seca 750Comment
Upshift or downshift, you don't really need to do more than pre-position so you're ready to shift. Preloading or taking up slack if your shifter/linkage is in good shape will wear the trans/shifter parts and it's a really bad habit to get into. When you hit a bump, eat a bug or Murphy just drops by to say, "Hello! Remember me?" you're unexpectedly in between gears and switching to glide.Preload to my mind is putting pressure on the shifter/gears anticipating that a reduction of power by chopping the throttle will cause the preload (pressure/tension) to allow the gears to change.
Learn the engine RPM ranges for the gears and get the feel of the load on the drivetrain when you're accelerating, decelerating or cruising. The idea is to temporarily unload the gears, then match the engine RPM for the new gear while you shift.
You can practice at low speed on a deserted street or parking lot so you don't tear up parts or get turned into a semimetallic grease stain while you learn the machine.
♬Comment
I was just "back" into my tranny for a 2nd Dremel fix on my 1st gear that past summer. I had done my original repair in 2000. I shift using the clutch, the later model years WITHOUT the kickstarter parts is what allows the gears to be a little more loose and allows for more wear, per 3Phase evaluation.
Preloading the shift lever would put some pressure on the shift drum which then puts pressure on the shift fork, which rubs against the gear as it's spinning, and so I could see this repeated process causing excessive wear on the shift fork tangs. Just shifting clutchless wouldn't necessarily cause this wear, but pressuring/preloading the shift lever could....IMHO.
XJkid, you say it's shifting HARDER, what exactly do you mean by that, that it doesn't slip into the next gear as easily/quickly, you end up misshifting or what? There is an alignment adjustment for the shift pawl and drum assembly, yours may be out of alignment so that the pawl isn't grabbing or rotating the drum completely like it should. See the tech tips for images and info on how to set/adjust the alignment, it's checked when trans is in 2nd gear, shift cover off.
T.C.T. C. Gresham
I would think that 1st gear issues are caused by misadjusted clutch or slamming it into gear initially since the only shifting that takes place while the bike is moving for 1st is downshifting. Anyone trying to upshift into 1st without the clutch would most definitely have issues.
On the later models without the kicker idler gear to help stabilize and damp the 1st gear wheel, every shift into 1st makes that stonkin' great gear wheel ring like a bell.
The ringing accelerates the wear on the soft bronze(?) bushing in the center of the 1st gear wheel that's supposed to let it sit pretty on its steel bushing on the transmission shaft. Eventually, the bushing wears enough to wobble slightly when it gets whacked into gear, not just ring.
When the bronze bushing wears enough that the 1st gear wheel can 'tilt' and the slots move away from the 4th gear dogs during a shift then it'll start rounding off the slots/dogs until they wear down enough to skip under load or pop out of gear.
I think the Yamaha rice counters figured that most of the transmissions would last long enough to clear the warranty period and they'd save saki money on kicker idler gear assemblies.-- Scott
♬Comment
So it is a bushing thing? I guess I have always been lucky with all 4 of the xs11's I have owned. Never had transmission issues. I always use the clutch downshifting (except getting home once when I had a broken cable) and nearly always use it upshifting. I did notice that gear meshing is better without the clutch if shifting at lower rpm ranges...On the later models without the kicker idler gear to help stabilize and damp the 1st gear wheel, every shift into 1st makes that stonkin' great gear wheel ring like a bell.
I think the Yamaha rice counters figured that most of the transmissions would last long enough to clear the warranty period and they'd save saki money on kicker idler gear assemblies.Skids (Sid Hansen)
