Oil leak around the #4 cyl exhaust....
  • ERM83
    • Apr 2016
    • 314
    • Lehigh Valley, PA
    Can it leak where the exhaust nuts are?? It's been a while since I've fiddled with the exhaust...last time was a year and a half ago on the other xs (SF). Can't remember what it looks like in there! Sorry if I sound ridiculously stupid...just wanted to ask the masters before I do ANYTHING on it tomorrow!! I've been trying to pinpoint this leak for a while now...thought it was the cam caps, but definitely isn't. Doesn't leak profusely, but enough to be a bit messy after a few days...
    Eric
    80' XS1100 SG "Dottie"
    79' SF carbs
    MAC 4-1
    K&N Pods
    Accel 3.0 coils
    Tarozzi fork brace
    TC fusebox
    Picture update soon
    http://i53.photobucket.com/albums/g4...psej6wqu9l.jpg
    79' XS1100 SF (parts, will be reborn)
    http://i53.photobucket.com/albums/g4...snfgpozqn.jpeg
    • 2138
    Valve Cover Gasket
    I doubt the exhaust would leak oil.
    The most likely cause for oil on #4 exhaust would be the valve cover gasket. There are water drainage passages in the head that can disguise a valve cover leak. Usually, you can just tighten the valve cover bolts to stop a leak.
    The cam chain tensioner is between #2 and #3 exhaust. It is notorious for leakage around the rubber coated plug at the end of it. But that is in a different area.....
    • ERM83
      • Apr 2016
      • 314
      • Lehigh Valley, PA
      See, that's the weird thing...it doesn't start at the valve cover gasket. It starts RIGHT where the exhaust/ exhaust nuts are. I'll try to get some pictures. The gasket mating surfaces are dry...
      Eric
      79' SF carbs
      MAC 4-1
      K&N Pods
      Accel 3.0 coils
      Tarozzi fork brace
      TC fusebox
      Picture update soon
      • donebysunday
        • Oct 2012
        • 1737
        • New Berlin, Wi.
        Eric
        Had the same thing, swore it was not the valve cover. The knowledgeable folks here tried to convince me and I eventually listened. Pulled the valve cover, (for once the P.O. did good and cemented the gasket to the cover) put a fine bead of sealant on the gasket engine side and no more oil on the exhaust flange.
        76 XS650 C ROADSTER
        80 XS650 G Special II
        https://ibb.co/album/icbGgF
        80 XS 1100 SG
        81 XS 1100LH/SH DARKHORSE
        https://tinyurl.com/k6nzvtw
        AKA; Don'e, UD, Unca Don'e
