rear tire bearings and seals
  • Jeffintampa
    • Apr 2011
    • 344
    • Zephyrhills, Florida
    hello guys,
    I have ordered the easy to get bearing and seals from the dealer and am going to call Motion industry Monday morning. I am going to try to change it all.
    Question I have is there a process for removal is it hard?
    is there a process thread?
    Thanks
    Bike History:1980 XS 1100 special current bike
    1980 XS 850 special wife sold
    • 2098
    Here ya go bud . . .
    The following threads should get ya into just enough trouble
      • 2098
      Also while Yer in Der . . .
      Swing arm bearings most likely need some Luvin'
        Hey Jeff,
        Have you checked the large/wide left side rear bearing to make sure it's still good, smooth? It's available, here's one on AMAZON:
        THIS LISTING IS FOR 1 PIECE - NTN NA5904 MACH RING NRB (MACHINED RACE) MACHINED RING NRB W/ INNER RING - 20 MM ID X 37 MM OD X 23 MM W, UPC Number: 4547359113679, FACTORY NEW!
        https://www.amazon.com/NTN-MACHINED-...70_&dpSrc=srch
        • Jeffintampa
          • Apr 2011
          • 344
          Thanks
          Guys thank you so much as always.
          • Solonys
            • Jun 2017
            • 20
            • Spokane, WA.
            Hey Jeff,
            T.C., does this replace the 93313-62010-00 bearing that is NLA from Yamaha?
            Bertha - 1978 XS1100E
              • 2140
              Yup
              Yes, 93313-62010-00 is the bearing that is the same as NA 5904
                Just be careful with the searches, there's an NKIA 5904 that says Needle Bearing, but it's got roller ball bearings on one end/side compared to the NA5904 that is total needle bearings as it should be.
                • rangerguy302
                  • May 2014
                  • 125
                  • Billings Montana
                  Wow I thought that bearing was not available any where, no longer manufactured . I'll have to get a couple.
                  79 XS11 F
                  • gene
                    • Mar 2009
                    • 267
                    • Weston, Fla.
                    I just ordered one as well.
                    Thanks for the lead.
                    Gene
                    Gene (Florida)
                    1980 XS1100SG
                    Accel Coils
                    4-1 Jardine Exhaust
