Headlight / running light mods...(needing guidance)
    • 5061
    It must have a built-in gyroscope that senses vertical when it calibrates. This would require a momentary switch or an off-on switch.
      Hey there Eric,
      Okay, I used the AUX terminal for mine, run a good 14Ga wire from there to a RELAY that will then go to the FUSED power line of the light set. I don't know how the provided harness or switch is setup. Some lights might use their mounting for frame ground, others provide a ground in with the harness.
      I tapped into an OEM harness power line to provide the other power line for the switch to be able to throw the relay. If the switch is built in to the harness, then it's probably just a simple INLINE switch.
      Hope the AUX lights you found are LEDS. Would still suggest getting and trying just a replacement H4 hi power LED bulb for the OEM headlight reflector, if it has one that takes replacement bulbs vs. Sealed Beam
      • ERM83
        • Apr 2016
        • 314
        • Lehigh Valley, PA
        Here's what I have...
        Not sure what kind of relay to get...this is a big weak point for me. I've NEVER messed with anything involving an auxiliary power source on a bike!
        80' XS1100 SG "Dottie"
        79' SF carbs
        MAC 4-1
        K&N Pods
        Accel 3.0 coils
        Tarozzi fork brace
        TC fusebox
        Picture update soon
        http://i53.photobucket.com/albums/g4...psej6wqu9l.jpg
        79' XS1100 SF (parts, will be reborn)
        http://i53.photobucket.com/albums/g4...snfgpozqn.jpeg
