81' Special re-hab
  • spectra
    • Aug 2017
    • 113
    • Vancouver, WA
    #46
    No pics?
    We need pics
    79 SF
    • SNDSLGR
      • Jul 2017
      • 34
      • Beaverton Oregon
      #47
      Are all those pics not showing up? I put up about ten yesterday
      81' Yamaha XS1100SH
      15' Harley-Davidson Ultra Limited
      • spectra
        • Aug 2017
        • 113
        • Vancouver, WA
        #48
        Nope just little black boxes with an x in it.
        Pics stink now that photobucket took a crap.
        79 SF
        • SNDSLGR
          • Jul 2017
          • 34
          • Beaverton Oregon
          #49
          anyone else? can you see my pics on this thread?
          81' Yamaha XS1100SH
            • 2104
            Not a one
            • dansmith65
              • Aug 2017
              • 141
              • Kootenays, BC , Canada
              #51
              FYI: A good way to see the same thing others are seeing is to use an "Incognito Window", or "Private Browsing" (different browsers use different terminology). I often use that to test public links before sending them to someone. The reason you can see the images is because your logged into your google account in your browser. If you open an "Incognito Window", then that window won't be logged into your google account, so you can see what we're seeing.
              80 SG Canada
              • SNDSLGR
                • Jul 2017
                • 34
                • Beaverton Oregon
                #52
                This seems to work?? (thanks for the incog idea)
                81' Yamaha XS1100SH
                  • 2104
                  Yep . . .
                  Pics are comin' through now, looks good, got more ?
                  • SNDSLGR
                    • Jul 2017
                    • 34
                    • Beaverton Oregon
                    #54
                    Cut the mufflers just rear of the dimple about 4" behind the smallest part of cone.
                    Next if you look close there is a slight bulge 1/2" behind the weld. I marked it with a sharpie to use as a guide once I break thru first tube. The exhaust is double walled here, the inner tube reduces and the outer tube expands at this point.
                    Use a cutoff wheel and carefully cut off the outer ring only, leave the inner tube in tact to sleeve over later.
                    81' Yamaha XS1100SH
                    • SNDSLGR
                      • Jul 2017
                      • 34
                      • Beaverton Oregon
                      #55
                      Put the headers back on bike and figure out mounting etc for mufflers. For the Supertrapp mufflers I chose (443-1717) I need a 5" extension to make it work.
                      The inner tube is 1-5/8" OD. A piece of 1-3/4" exhaust pipe is a near perfect fit to slide over the stub. Weld it up and grind it down smooth.
                      Mock up shot. I cannot weld SS so will have to get the bike over to my buddies house. I plan to make a SS mount tab like the stocker and get ride of the strap at a later date.
                      81' Yamaha XS1100SH
                      • SNDSLGR
                        • Jul 2017
                        • 34
                        • Beaverton Oregon
                        #56
                        2 of 3 bolts snapped on each header when I removed the heat shields. I used a dremel cutoff wheel to cut what I could of the weld and then a chisel and hammer to remove old threaded bung so I could weld new nuts into place.
                        81' Yamaha XS1100SH
