Stupid Shim Question
  • txtriathlete
    • Sep 2017
    • 35
    • Rapid City, SD
    Measured all the cam/shim clearances when I had the cover off, all were tighter (closer) than what is spec'd. For some reason in my head I was thinking they should be higher (looser) than spec if they need to be adjusted - like a wear part wearing down a surface.
    I recently read something somewhere (KZ1000 forum?) that made me think they might get tighter as they go out of spec? Which way do they wear - tighter or looser?
    Either way it looks as if I am gonna be getting my shim on...got fire shooting out of the exhaust ports (pipes are off) when I turn it over...that can't be good...gotta check timing.
    But it is running.
    80 SG
  • tcoop
    • Nov 2009
    • 793
    • South Weber, UT
    As the valves where into the heads the gap gets tighter. So as the gap get tighter you need to change out to a smaller shim to set the gap into specs.
    Ty
    78 XS1100E - Now in Minnesota
    80 XS1100LG - The Punisher
    82 XJ1100 - Daughter's Bike
      As Ty said, the shims get tighter as the valve seats wear, and you need to change to a 'thinner' shim.
      My bikes seem to shift about 1 shim size very 10,000 miles.
        Hey Tx,
        If you didn't pull each shim after checking clearances, you will want to do that to document each ones sizes. Because sometimes you will find one that may work for another valve location, and therefore need to replace less than all 8.
        • MPittma100
          • Aug 2011
          • 2359
          Maximum Gap
          Set the clearances to the maximum spec. This will allow longer intervals between adjustments.
          1981 XS1100H Venturer
          K&N Air Filter
          ACCT
          Custom Paint by Deitz
          Geezer Rectifier/Regulator
          Stebel Nautilus Horn
          EBC Front Rotors
          Limie Accent Moves On In 2015
          Mike
          • myac455
            • Jul 2017
            • 72
            • Mayer, AZ
            Mine were dead nuts on , on the exhaust cam.
            3 of the four intakes were under a few thou .
            Still at about .004 (We don't talk mm. here. I'd have to buy a new feeler gauge)
            Anyone ever found a used bike @.000 , and the cam worn?
            I figure I can get the bike going and ride it around some, and deal with it later.
            Mark Yac
            79 Former Police XS 1100
            Real life never quite adds up
            • mack
              • 2411
              • Ontario, Canada
              shimming
              As a general rule of thumb. When these motors get quiet, it's time for a shim adjustment.
              mack
              79 XS 1100 SF Special
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              https://youtu.be/wB5Jfbp6SUc
              https://youtu.be/RaI3WYHSuWA
              Frankford, Ont, Canada
              613-398-6186
              • myac455
                • Jul 2017
                • 72
                • Mayer, AZ
                Thanks. Makes sense.
                Never thought of it, seeing I only had mine running for 20 seconds, before I tore it all apart.
                Mark Yac
