Tiny Speedo Screw
  • txtriathlete
    • Sep 2017
    • 35
    • Rapid City, SD
    Tiny Speedo Screw
    Missing one of the two tiny screws that holds the faceplate on the speedo on my 80 SG. Looks to be a 2 mm pan head type screw. Tried the nuts and bolts at ACE with no luck, they only go down to 3 mm.
    Watch shop? Who sells tiny little screws like that?
    80 SG
    • 8891
    Try a hobby shop or electronics shop. May be able to find one from an old computer.
    • DaveT
      • Aug 2017
      • 41
      • Spokane, WA.
      Try one of the fastener companies like Fastenal.
        • 5073
        Walmart's eyeglasses shop?
        • donebysunday
          • Oct 2012
          • 1737
          • New Berlin, Wi.
          One
          I looked and looked, I've worked so many tachs and speedos, I've extra faces, needles, rims, dampeners, rings etc.
          I found one screw, could you use it ?
          Don'e ph.#414-333-3899
          76 XS650 C ROADSTER
          80 XS650 G Special II
          https://ibb.co/album/icbGgF
          80 XS 1100 SG
          81 XS 1100LH/SH DARKHORSE
          https://tinyurl.com/k6nzvtw
          AKA; Don'e, UD, Unca Don'e
          • txtriathlete
            • Sep 2017
            • 35
            • Rapid City, SD
            Thanks for the good suggestions. Think I'll start with Walmart and work my way through the options. I assume eyeglasses screw is metric since everything is made in Asia these days. Thanks for the kind offer Done, and thanks for taking time to search! Give me a day or two to try and find one locally and if I can't get one I'll call.
            80 SG
