More questions for the experts
  • sorbemca
    • Nov 2016
    • 8
    • San Diego, CA.
    Hi,
    I'm rehabilitating a '79 SF and could use some assistance from the experts here.
    As we know the Special is "special" and has some unique features. Does anyone have a link to the parts drawings of the Special? I can find the "F" model drawings, but nothing on the "SF".
    First the front brakes need work, I've sourced a new MC from Mikes, as well as new pads, steel braid hoses, and rebuild kits from other sources. New pistons from HVC are on order too. I want to replace the o-ring in the caliper mounting bolt assy, anyone know what size it is?
    All the petcock rebuild kits I see are missing the drain plug screw sealing washers. Anyone know what size that one is? My 1980 Cymer manual does not give the exact size.
    Thanks in advance. I'm also looking for a Special fork brace (I've posted in looking for parts too)
    Sorb
    79 SF
    Originally posted by sorbemca
    Hi,
    Sorb
    78E is Standard only for that yr.
    79F is Standard only
    79SF is Special only
    80G is Standard only
    80SG is Special only
    81H is Standard(Venturer) only
    81SH is Special only
    Then you also got 80-81 Midnite Specials(MNS).
    As for the fuel bowl drain gasket, take that drain plug with you to a parts store and find either a fiber or copper washer for sealing....easy-peasy.
      Here you go, one fiche, coming up!
      XS11.com Forums > Idle Talk Forum > Links > The missing 79SF parts fiche
      • sorbemca
        • Nov 2016
        • 8
        • San Diego, CA.
        Thanks
        Originally posted by 3Phase
        Thanks 3Phase, at least now I know the part numbers of the parts I can't find
        It's all about the journey, how is your SF?
        Sorb
        79 SF
        • mack
          • 2411
          • Ontario, Canada
          Try this one
          mack
          79 XS 1100 SF Special
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          https://youtu.be/wB5Jfbp6SUc
          https://youtu.be/RaI3WYHSuWA
          Frankford, Ont, Canada
          613-398-6186
            Sorb
            You're welcome, Sorb!
            The Special's actually doing good, thanks, I had the center stand brackets and the tail pieces of the frame re-welded, now it's mostly just paint and reassembly. Te Deum.
            • sorbemca
              • Nov 2016
              • 8
              • San Diego, CA.
              Thanks Mac
              Originally posted by mack
              Thanks for the link.
              Always looking for sources of parts.
              Sorb
              79 SF
              • mack
                • 2411
                • Ontario, Canada
                That's
                a good link because it still has the parts fiche for all the XS models.
                mack
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                613-398-6186
