vacuum at idle
  • red bandit
    • 970
    • central michigan
    vacuum at idle
    Brent, I know it's supposed to be 20in. Sorry if I made it sound like you were wrong. The only thing I have never checked is valve timing. But if valve timing is off that bad wouldn't I have lower compression (175psi)? 39 MPG. It seems to run great. I say "seems" because I have never had it on a dyno or road with another 11.
    79 SF parts bike.
    No apology needed, as I already knew my statement was correct. To add, that vacuum at sea level is normally 22in.vac. and at 10-12,000ft. elev. it drops to 16in. vac. I just know this from using a mas-port vacuum pump at a variety of elevations, which was work related at the time.
      Also, those variations of vacuum based on elevations is why these vacuum slide/metering rod operated carbs are altitude compensating to a certain extent......less vacuum equals less rise of slides/metering rods that push up against vacuum slide sring assembly, which in turn equals less fuel/air as elevations rise.
