I have a question about changing the motor oil on my 1979 XS Special.
1) Is the regular engine oil separate from the case for the clutch?
Can you use synthetic?
2) The drive shaft oil or lube, how do you change and flush it? and what weight of oil does one use for that?
3) Also, I am a big fan of sea-foam for fuel additive, does anyone recommend to use with crankcase oil for engine flush?
Thanks,
Thanks,
. Caption Zap may chime in verifying and explaining how location and angle of grease zerk MORE than lubricates those splines!
