Trans..2nd gear/ Tremel Tricks..one more time
  • myac455
    • Jul 2017
    • 72
    • Mayer, AZ
    Guys, Seeing I've got my bike all stripped down, I thought I'd take a look at the trans.
    I did a search last night, and spend several hours reading about a neat chopper, and a few other mentions of 2nd gear, but I never found the how-to stuff.
    I looked under info/ tech tips/ trans ??
    Is there a sticky somewhere that I'm missing?
    Thanks in advance
    Mark
    Mark Yac
    79 Former Police XS 1100
    Real life never quite adds up
  • TruthHammer
    • Jun 2017
    • 65
    • Carmel, IN
    SF / SH Frankenbike
    • SF - frame, carbs
    • SH - engine
    • TBD - everything else
    • myac455
      • Jul 2017
      • 72
      • Mayer, AZ
      Originally posted by TruthHammer
      Thank you ,Sir
      Mark Yac
      • myac455
        • Jul 2017
        • 72
        • Mayer, AZ
        Thanks in advance
        Mark
        Of course, that would be Dremel, or in my case , a H-Femel.
        Works okay. I bought it 10 years ago to slick shift a T-5 trans. Still working!
        Their electrical stuff seems to be okay. Air tools? Junk
        Mark Yac
        • Tenorman
          • Oct 2013
          • 70
          • Butler, Penn.
          My thoughts on "new" gears...and the Dremel Fix...
          I don't want to start on a war on the Dremel Fix, but when I did my bike two years, I searched for new gears from Partzilla.
          The 1st Gear was still available, but they showed that the 4th Gear was, but later emailed me that it wasn't. I bought the 1st gear (about $100.00 with shipping).
          I found another 2 NOS gears on eBay...4th and 2nd...bought them...about $100.00 each. I then bought a good used transmission on eBay...another $100.00.
          You'll look long and hard to find the 5th gear although they do come up on eBay once in a while...maybe $100.00 if you're lucky.
          I ended up using the 5th gear from the used transmission along with the 2nd gear washer. (I had the new second gear cut so I could use 2 washers...one on either side.)
          If I had to do it all over again, I would have contacted these people
          http://www.fastbygast.com
          The FJ owners site has a ton of information on these transmissions, because they also had problems with the 2nd gear on the early FJ1100 and FJ1200.
          By the way...I never found a NOS gear that was undercut...I don't think that they ever existed. All that I found was NOS...NEW OLD STOCK...
          Hope this helps....
          Tenorman
          Bikes that I have owned and enjoyed...
          1964 Allstate 250
          1970 Yamaha DT1
          1959 Mobylette
          1970 Yamaha JT1
          1995 Suzuki 80
          1978 Yamaha XS650
          1980 Yamaha XS1100LG
          2005 BMW R1150R
          • myac455
            • Jul 2017
            • 72
            • Mayer, AZ
            Thanks for the info.
            I'll get into mine in a week or so.
            I have no idea on the miles on mine , but I know it's got plenty of years of use.
            I guess it's just something that has to be dealt with on these bikes.
            I'll make it drive-able and dependable some way.
            Not going to be power shifting and yanking the wheel in every gear, like in the 70's. LOL
            Mark Yac
              Hope this helps....
              Tenorman
              I concur. New gears were still available when I did mine. Today, I'd want a precision grind followed by case hardening.
