Xs1100 shift lever does nothing
  • scratcher09
    • Dec 2013
    • 19
    • San Antonio, Tex.
    I recently got my 1980 Xs11 running and a few blocks from my house, while going from 2nd to 3rd, it popped into neutral. I pulled over and the shift lever moves up or down but will not shift gears. It stays in neutral. Any input would be greatly appreciated.
    80 LG
  • mack
    • 2411
    • Ontario, Canada
    you'll
    need to remove the shift lever and pull the cover off. Could be the springs are not returning the mechanism. Show us a picture when you get the cover off. Work off the center stand. To check the alignment dots it needs to be in second gear but hard to do if the lever isn't working. There are some c clips in there that may have come off and allowed the shaft to slide out a bit so the mechanism isn't meshing.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      I think we all would like to know the outcome, please ?
      76 XS650 C ROADSTER
      80 XS650 G Special II
      https://ibb.co/album/icbGgF
      80 XS 1100 SG
      81 XS 1100LH/SH DARKHORSE
      https://tinyurl.com/k6nzvtw
      AKA; Don'e, UD, Unca Don'e
      • scratcher09
        • Dec 2013
        • 19
        • San Antonio, Tex.
        Here's my problem.
        80 LG
        • scratcher09
          • Dec 2013
          • 19
          • San Antonio, Tex.
          How can I attatch a photo without using Photobucket?
          80 LG
            • 2104
            Photos
            Here ya go:
            Provides free image uploading and hosting integration for forums. Free picture hosting and photo sharing for websites and blogs.
              My initial bet is one of the pins has fallen out due to the star washer having a bent retaineing ear. As stated, pull that left shift cover to inspect that that has happened. If so, that retaining ear on the the star washer, if straightened back WILL just break off.
              • scratcher09
                • Dec 2013
                • 19
                • San Antonio, Tex.
                I can't figure out how to post pics so I will try to describe it. The arm on the shift shaft which has teeth in it broke off. I welded it back together and welded some extra material to it for strength. It works fine now.
                80 LG
